Home » Language IDEs » Java Development Tools (JDT) » Log4j Java 9+ Module not found by Eclipse(Discovering Java modules)
Log4j Java 9+ Module not found by Eclipse [message #1791195] Mon, 25 June 2018 19:35 Go to next message
Sverre Moe is currently offline Sverre MoeFriend
Member
I thought at first Log4j 2.x wasn't an Java module, and it does not have an Automatic-Module-Name.
It appears that Log4j API is a Java Module with an module-info.class.
Even though log4j-api.jar is on the project modulepath in eclipse, Eclipse cannot find that module.
The module-info.class is not in the placed at the package root, but at META-INF/versions/9/
Because of this Eclipse cannot find out that Log4j is a Java Module.
Is this a known problem with Eclipse?
Eclipse Java EE IDE for Web Developers.
Version: Oxygen.3a Release (4.7.3a)
Build id: 20180405-1200
Building with gradle works fine. Gradle finds the log4j module.
I had to write the logging code without the support of Eclipse IDE and that was a real pain.
module-info.java
module no.djviking.movies {
    requires javafx.controls;
    requires javafx.fxml;
    requires javafx.web;
    requires javafx.graphics;
    requires org.apache.logging.log4j;
org.apache.logging.log4j cannot be resolved to a module
import org.apache.logging.log4j.Logger;
class MoviesApplication {
The type org.apache.logging.log4j.Logger is not accessible
Re: Log4j Java 9+ Module not found by Eclipse [message #1791212 is a reply to message #1791195] Tue, 26 June 2018 05:32 Go to previous message
Sarika Sinha is currently offline Sarika SinhaFriend
Created Bug 536273 . https://bugs.eclipse.org/bugs/show_bug.cgi?id=536273http://
Sarika Sinha
JDT Programmer
Previous Topic:Update site for Target Management is down
Next Topic:Focus losing when .xml file opened with CTRL-SHIFT-R
Current Time: Thu May 23 12:47:50 GMT 2024
Powered by FUDForum. Page generated in 0.03432 seconds
