Home » Language IDEs » ServerTools (WTP) » IBM Contribution feedback
IBM Contribution feedback [message #33903] Wed, 28 July 2004 07:14 Go to next message
The first think I would like to tell - the contribution is great!
But those are the problems I have found:
1. If I associate XML Editor with some file extension by hand (for
example *.wml) the encoding of the file is not determined and I cannot
find the way how to set it by hand too.
2. I've added some XML Schema to XML Catalog preference page, but when I
edit file with namespace defined by this schema content assist does not
use schema for proposals. If not yet available DTD and XML Schema based
content assist should work in final product.
3. Missing support for XSLT Editing and XSLT Debugger.
Are any of the abowe features planned? And if yes when it could be expected?
Re: IBM Contribution feedback [message #34342 is a reply to message #33903] Thu, 29 July 2004 10:32 Go to previous messageGo to next message
Thanks for the feedback Igor. I'll attempt to answer some questions.
1. If you use the new XML wizard it will create a file for you with
content like this '<?xml version="1.0" encoding="UTF-8"?>'. Are you asking
for the UI or source view to help you specify an encoding? If so a quick
description of what you'd expect (menu item, content assist?) would be
helpful. I know we do provide content assist support for adding the xml
declaration.
2. Sounds like a bug. If you'd like to send me your schemas and xml files
I can look into it further.
3. XSLT Editing and debugging isn't included in our planned contribution
though IBM does provide this function in our 'not for free' WSAD/RAD
products.
Hope that helps!
cs
Re: IBM Contribution feedback [message #34749 is a reply to message #34342] Thu, 29 July 2004 16:23 Go to previous message
On second thought (instead of sending me your xml/xsd's in an email)
please open a bugzilla bug against the 'Web Tools' product and attach your
artifacts.
thanks
cs
> declaration.
> products.
> Hope that helps!
> cs
expected?
Previous Topic:Idea for addressing the prerequisites problem - move EMF, GEF, and XSD to Platform
Next Topic:Is this a problem with the dtd validator or a problem in the dtd?
Current Time: Thu Jul 17 23:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.09281 seconds
