Home » Modeling » M2T (model-to-text transformation) » [JET] Returning a List from a custom XPath function.
[JET] Returning a List from a custom XPath function. [message #33901] Mon, 17 September 2007 09:26 Go to next message
Hi Paul, everybody.
I'm working on a second XPath function (stereotypeSearch)that returns a
list containing all elements from a model stereotyped with an stereotype
provided as an input parameter.
The XPath function works fine, and returns what it is supposed to
return. However, I can't find the way to access the elements contained
in the result List.
For example, when looking for the elements stereotyped 'message', I
tried using:
A) <c:iterate var="stereotypedElements"
select="stereotypeSearch($someElement, 'message')">
and
B) <c:setVariable select="stereotypeSearch($someElement, 'message')"
var="messages"/>
<c:iterate select="messages"...
with no satisfactory results. With A I got a message "Cannot iterate if
expression is: stereotypeSearch(...", and with B I get no results (no
iteration).
I am assuming that a List (or any kind of set) is not a valid return
type for an XPath function to be handled by JET, am I right?. Is there
any way to do this?.
Thank you in advance.
Juan Pedro
Re: [JET] Returning a List from a custom XPath function. [message #33966 is a reply to message #33901] Wed, 19 September 2007 09:44 Go to previous messageGo to next message
Juan Pedro:
The XPath engine is looking for instances of org.eclipse.jet.xpath.NodeSet.
I have submitted a bugzilla suggesting an enhancement to the XPath engine so
that it would recognize Java collections and arrays as equivalent to
NodeSet. In the meantime, I have created a utility class that will wrap an
Java collections and arrays.
The bugzilla is: 203970
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=203970)
The utility class is attached to the bugzilla, and to this post.
Let me know if this helps.
Paul
"Juan Pedro Silva" <jpsilvagallino@gmail.com> wrote in message
news:fclva5$hlr$1@build.eclipse.org...
> Hi Paul, everybody.
> in the result List.
> tried using:
> and
> var="messages"/>
> iteration).
> Juan Pedro
Re: [JET] Returning a List from a custom XPath function. [message #34058 is a reply to message #33966] Wed, 19 September 2007 11:08 Go to previous message
Paul, so far I've only tried a simple use of public static NodeSet
asNodeSet(Collection collection), but so far it's working fine.
I was going in that direction myself.
Thank you very much for you help.
Juan Pedro
Paul Elder escribió:
> Juan Pedro:
> Paul
>> Hi Paul, everybody.
>> in the result List.
>> tried using:
>> and
>> var="messages"/>
>> iteration).
>> Regards,
>> Juan Pedro
Previous Topic:Merging of import statements not working?
Next Topic:[JET2] Customizing an iterate sentence
Current Time: Mon Jul 14 23:37:39 EDT 2025
Powered by FUDForum. Page generated in 0.27136 seconds
