Home » Eclipse Projects » Eclipse Platform » activeWhen and enabledWhen problem
activeWhen and enabledWhen problem [message #334167] Thu, 22 January 2009 21:21 Go to next message
Originally posted by: kathir.atc.tcs.com
[XML]
<activeWhen>
<with
variable="activePartId">
<equals
value="com.seq.view.DatabaseManagerView">
</equals>
</with>
</activeWhen>
<enabledWhen>
<with
variable="myVariable">
<equals
value="true">
</equals>
</with>
</enabledWhen>
[XML]
when the 'myVariable' is false and when i click on the DatabaseManagerView ,
the command is inactive - which is right. But when i click on a different
view say Package Explorer the command gets enabled ( the toolbar icon gets
enabled ). Isnt that supposed to remain inactive because the active part is
changed and doesnot meet the activeWhen condition.
Kathir.
Re: activeWhen and enabledWhen problem [message #334170 is a reply to message #334167] Fri, 23 January 2009 01:35 Go to previous messageGo to next message
You might be having another handler which is active in other view. Did you
define a default handler for that command?
- Prakash
http://blog.eclipse-tips.com
"Kathir" <kathir@atc.tcs.com> wrote in message
news:glb9jm$9qs$1@build.eclipse.org...
> [XML]
> <activeWhen>
> <with
> <equals
> </equals>
> </with>
> </activeWhen>
> <enabledWhen>
> <with
> <equals
> value="true">
> </equals>
> </with>
> </enabledWhen>
> [XML]
> , the command is inactive - which is right. But when i click on a
> different view say Package Explorer the command gets enabled ( the toolbar
> icon gets enabled ). Isnt that supposed to remain inactive because the
> active part is changed and doesnot meet the activeWhen condition.
> Kathir.
Re: activeWhen and enabledWhen problem [message #334175 is a reply to message #334170] Fri, 23 January 2009 05:55 Go to previous messageGo to next message
By the way, very interesting your blog http://blog.eclipse-tips.com to any
Eclipse developer. :-)
> - Prakash
Re: activeWhen and enabledWhen problem [message #334184 is a reply to message #334170] Fri, 23 January 2009 13:08 Go to previous message
Thanks prakash..I had a default handler which was causing it to enable.
kathir.
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:glboer$k7v$1@build.eclipse.org...
> - Prakash
>> [XML]
>> <activeWhen>
>> <with
>> <equals
>> </equals>
>> </with>
>> </activeWhen>
>> <enabledWhen>
>> <with
>> <equals
>> value="true">
>> </equals>
>> </with>
>> </enabledWhen>
>> [XML]
>> DatabaseManagerView , the command is inactive - which is right. But when
>> i click on a different view say Package Explorer the command gets enabled
>> ( the toolbar icon gets enabled ). Isnt that supposed to remain inactive
>> because the active part is changed and doesnot meet the activeWhen
>> condition.
>> Kathir.
Previous Topic:How to provide duplicating a file within a project ?
Next Topic:Duplicate plug-in entries in "Plug-in Details"
Current Time: Fri Jul 18 08:20:24 EDT 2025
Powered by FUDForum. Page generated in 0.11960 seconds
