Home » Eclipse Projects » Eclipse Platform » how to add a file necessary to run the plugin?
how to add a file necessary to run the plugin? [message #334114] Wed, 21 January 2009 07:40 Go to next message
Hello!
I'm developing a plug-in project, and need a file that contains some
important info. This file ("config_file.xml") is already created and is
located in the "src/" folder of my plugin.
How can I locate this file with a relative path to the plug-in? Do I need
an specific extension-point?
Thanks for your help!!
Re: how to add a file necessary to run the plugin? [message #334126 is a reply to message #334114] Wed, 21 January 2009 10:31 Go to previous messageGo to next message
Within your own plugin, you can either use
getClass().getResourceAsStream(*) or Bundle#getEntry(*)
PW
Paul Webster
Re: how to add a file necessary to run the plugin? [message #334178 is a reply to message #334126] Fri, 23 January 2009 08:40 Go to previous message
Thank you Paul!
Your comment was really important to solve my problem. I finally found the
way to get the path of my files:
URL url = FileLocator.find(Activator.getDefault().getBundle(), new Path
("src/config.xml"), null);
URL fileUrl = null;
fileUrl = FileLocator.toFileURL(url);
File file = new File(fileUrl.getPath());
I found it on this website:
http://codeache.blogspot.com/2007/05/loading-files-with-rcp. html
Ciao!
Previous Topic:Maximize workbench window
Next Topic:How to provide duplicating a file within a project ?
Current Time: Mon Jul 21 22:56:07 EDT 2025
Powered by FUDForum. Page generated in 0.07135 seconds
