Home » Eclipse Projects » Eclipse Platform » Drag and Drop between 2 opened editors
Drag and Drop between 2 opened editors [message #334093] Tue, 20 January 2009 04:36 Go to next message
My application writing needs are to enable drag & drop between 2 opened editors.
While there is the possibility to open both editors side by side, it's not a well known feature, and sometimes not desirable.
What I would like is enable the user to work on several open editors, and, from time to time, initiate a drag operation from editor A, hovering the mouse over the tab showing the label of editor B,
which will then be opened to allow the drop operation to be done on editor B.
I don't know :
- if it is feasible at all ?
- if yes, where to plug things/start with ?
Thanks in advance if you can answer to my questions,
Laurent PETIT
Re: Drag and Drop between 2 opened editors [message #334109 is a reply to message #334093] Wed, 21 January 2009 05:49 Go to previous messageGo to next message
Does nobody have an idea to help me solve this problem ?
I've currently tried solutions such as adding listeners to the main shell directly, but have not succeeded yet.
Thanks in advance,
Laurent
Laurent Petit wrote:
> Hello,
> editors.
> hovering the mouse over the tab showing the label of editor B, which
> I don't know :
Re: Drag and Drop between 2 opened editors [message #334155 is a reply to message #334109] Thu, 22 January 2009 07:37 Go to previous messageGo to next message
This request for enhancement seems to be already there see https://bugs.eclipse.org/bugs/show_bug.cgi?id=37595 .
Do you have an idea of when it could be scheduled for implementation ?
Do you have an idea of how to make a specific plugin, in the special context of a drag operation initiated from one of the plugin's own views, solve this problem in this case (and not waiting for a
general solving solution including hover over views, hover over perspective buttons, ...) ?
Thanks in advance,
Laurent
> Hello,
> Thanks in advance,
Re: Drag and Drop between 2 opened editors [message #334158 is a reply to message #334155] Thu, 22 January 2009 10:05 Go to previous messageGo to next message
Your best bet would be to comment on the bug report, asking for the
current status. I see that it is in the ASSIGNED state which usually
means someone is actively looking at and/or working on it. But in that
bug, the most recent comments are at least 18 months old, so I'd guess
that the team has forgotten about it. If you add a comment, people will
get emailed and perhaps spring into action. Of course, if you can offer
to help implement the feature or part of it, I'm certain you'll get
their attention.
Eric
Re: Drag and Drop between 2 opened editors [message #334172 is a reply to message #334158] Fri, 23 January 2009 03:53 Go to previous message
Alas, I currently haven't reached the step where I could offer patches to the community, but any soon I feel I can, I certainly will if that can help.
You're right, I'll trigger an event on the bug itself, thanks for the idea,
Laurent
> their attention.
> Eric
Previous Topic:Programatically set Problem view filter
Next Topic:Purpose of DataBindingContext's validation realm
Current Time: Tue Jul 15 01:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.05718 seconds
