Home » Modeling » OCL » declaring a parameter of a operation of type Sequence
declaring a parameter of a operation of type Sequence [message #33898] |
Tue, 24 July 2007 11:41  |
Originally posted by: firstname.name.gmail.com
I successfully created some helpers in my UML environment. Now I would like to
create a operation with a sequence as parameter.
I get something like that,
variable = org.eclipse.ocl.uml.UMLFactory.eINSTANCE.createVariable();
variable.setType(getOCLStandardLibrary().getSequence());
variable.setName("sequence");
params.add(variable);
Operation myOperation = defineOperation(getOCLStandardLibrary().getOclAny(),
"myOperation",getBoolean(),params, constraint)
After I want to parse this query
"self.myOperation(Sequence{'aValueA','aValueB'})"
But my operation seems to be not identified. I get:
Cannot find operation (myOperation(Sequence(String))) for the type (NamedElement)
I tried with other type (boolean, string), and it works.
Do I have to precise the Type of the elements in the Sequence and how?
thanks a lots.
F. Lagarde
Re: declaring a parameter of a operation of type Sequence [message #33943 is a reply to message #33898] |
Tue, 24 July 2007 12:46   |
Hi, François,
The SequenceType instance needs to know what its element type is. Defining
the operation using the Sequence(T) generic type from the standard library
doesn't work because it doesn't know what its element type is.
Try this, instead:
variable.setType(org.eclipse.ocl.util.TypeUtil.resolveSequen ceType(
this, getOCLStandardLibrary().getString()));
constraint)
HTH,
Christian
François Lagarde wrote:
> Hello,
> like to create a operation with a sequence as parameter.
> constraint)
> (NamedElement)
> thanks a lots.
Re: declaring a parameter of a operation of type Sequence [message #33992 is a reply to message #33967] |
Wed, 25 July 2007 09:46  |
Hi, François,
I'm glad it works, now.
About the documentation: sure, feel free to raise an enhancement request.
The current implementation uses "addOperation"; the defineOperation
approach would be a nice alternative. If you can provide a variant of the
current example that uses defineOperation, that would be particularly
helpful :-)
Christian
> In the last post, on 07/24 about 06h, "Christian" (Christian W Damus)
> wrote:
> Christian> Hi, François, The SequenceType instance needs to know
> what its
> Christian> element type is [...] Try this, instead:
> Thanks for your reply. It works.
> between, the tutorial "Customizing the Environment" doesn't make any
> reference to the definition of a operation thanks to the method
> defineOperation. It could be helpful to mention it.
Current Time: Sun Jul 27 22:56:00 EDT 2025
Powered by FUDForum. Page generated in 0.05480 seconds
