Home » Eclipse Projects » Eclipse Platform » Maximize workbench window
Maximize workbench window [message #334071] Mon, 19 January 2009 03:44 Go to next message
This is another question I asked in another newsgroup but which I
haven't got an answer to so far. Again, maybe someone here can help me?
I have two workbench windows with several views. Window A is maximized
and active, window B is minimized to the task bar. Now I drag one of the
items from a view in window A over the minimized window B in the task
bar. But nothing happens. Window B doesn't get restored. If I wait and
then drop the item on window B I get the message that I need to hold the
item longer over the task bar. But that's the standard Windows message.
Is there a way to know when an item is dragged out of one window and
over the task bar and then to restore the window that the item is
dragged over?
Btw I'm using Eclipse 3.3.2 on Windows XP.
Kind regards
Bianca
Re: Maximize workbench window [message #334090 is a reply to message #334071] Mon, 19 January 2009 21:13 Go to previous messageGo to next message
Bianca,
Have you added drag / drop support in your window B. By your
description, I would first try and look into whether window B is
receiving drop events.
Hope it helps.
~Adil
> dragged over?
> Kind regards
> Bianca
Re: Maximize workbench window [message #334091 is a reply to message #334090] Tue, 20 January 2009 02:00 Go to previous messageGo to next message
Adil Fulara schrieb:
> Bianca,
Adil, thank you for your answer. In answer to your question, yes, I have
added drag and drop support. But only to the table viewer in window B
that's supposed to receive the drop event. It works fine as long as the
window isn't minimized to the task bar. Do I need to add the drag and
drop support to the window itself maybe?
Bianca
Re: Maximize workbench window [message #334169 is a reply to message #334091] Fri, 23 January 2009 01:30 Go to previous messageGo to next message
Bianca,
Sorry for the late response.
I think you would need to. The window will then get notified of the
drop. You could handle the drop based on the type of object received.
Why don't you give it a try? i think it should work then.
~Adil.
>> Bianca,
> Bianca
Re: Maximize workbench window [message #334174 is a reply to message #334169] Fri, 23 January 2009 05:32 Go to previous messageGo to next message
I noticed something today. When I minimize window B to the taskbar and
then drag - say - a folder from my Windows desktop over it, then window
B is maximized. So the problem is that I cannot drag an item from window
A to a minimized window B.
I then tried this with the Eclipse IDE. I dragged a source file from one
Package Explorer View to a new instance of the Eclipse IDE that was
minimized in the taskbar. The second instance was maximized as soon as I
dragged the source file over it.
The same is true of my application. If I start to instances of it, the
second instance is maximized as soon as I drag an item from instance one
over it.
My next test was then to open another window from my Eclipse IDE. I then
tried to drag the source file from window A of Eclipse to window B
(minimized). And - lo and behold - the minimized window wasn't maximized
when I dragged the source file over it.
I really do need to find a solution for this. Is there an event that I
could listen to? I haven't found one yet. If I don't find an answer the
work of over a year will be void.
Bianca
> Bianca,
> ~Adil.
>>> Bianca,
>> have added drag and drop support. But only to the table viewer in
>> window B that's supposed to receive the drop event. It works fine as
>> long as the window isn't minimized to the task bar. Do I need to add
>> the drag and drop support to the window itself maybe?
>> Bianca
Re: Maximize workbench window [message #334176 is a reply to message #334174] Fri, 23 January 2009 06:18 Go to previous message
> over it.
> Bianca
PS Maybe this is a Windows bug? I tried dragging an object between two
windows in Word and I couldn't get the second window to resurface once
it had been minimized to the taskbar.
Previous Topic:Purpose of DataBindingContext's validation realm
Next Topic:how to add a file necessary to run the plugin?
Current Time: Fri Jul 18 05:59:19 EDT 2025
Powered by FUDForum. Page generated in 0.10205 seconds
