Home » Eclipse Projects » Eclipse Platform » Turning on key bindings in an editor
Turning on key bindings in an editor [message #334025] Thu, 15 January 2009 20:48 Go to next message
(The following is happening in an RCP environment, but I doubt that RCP
has anything to do with it.)
In org.eclipse.ui.bindings, I've got a schema and a key.
I've got a command.
In my editor, I make the recommend call to activate my scheme.
My command is not called. My editor returns false to isEditable(), in case
that matters. Can anyone suggest a debugging strategy?
<extension
point="org.eclipse.ui.bindings">
<scheme
id="com.basistech.rex2009.annote.scheme"
name="Annotation Key Binding Scheme">
</scheme>
<key
commandId="com.basistech.rex2009.annotate.clear"
contextId="com.basistech.rex2009.annote"
schemeId="com.basistech.rex2009.annote.scheme"
sequence="CTRL+;">
</key>
</extension>
<extension
point="org.eclipse.ui.contexts">
<context
id="com.basistech.rex2009.annote"
name="Annotation"
parentId="org.eclipse.ui.contexts.window">
</context>
</extension>
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="com.basistech.rex2009.annote.ClearAnnotationHandler "
id="com.basistech.rex2009.annotate.clear"
name="Clear Annotation">
</command>
</extension>
Re: Turning on key bindings in an editor [message #334056 is a reply to message #334025] Fri, 16 January 2009 13:13 Go to previous messageGo to next message
> I've got a command.
You mean activate your context.
A Scheme is an over-arching set of keybindings. i.e. most RCP apps will
create and use one and only one scheme.
You can activate your keybinding by activating your context (which it
seems you've done) ... assuming your keybinding is in the current active
scheme. Your definitions all look correct.
PW
Paul Webster
Re: Turning on key bindings in an editor [message #334065 is a reply to message #334056] Sat, 17 January 2009 09:04 Go to previous messageGo to next message
Here's what I've learned. There is no API to change the current scheme
except by horsing around with preferences.
I expected to find some sort of WorkbenchAdvisor.getDefaultSchemeId(), but
no such luck. BindingService goes directly to the prefs.
IBindingService is entirely read-only. BindingService is in an internal
package and final.
Since I have an RCP app, I gave up and put my bindings in the default
scheme, and all works.
Now I need to dynamically create bindings. I can either play games
surrounding the IBindingService, or I can fake out the preferences, or I
can precreate all the possible bindings and then fiddle with handlers to
turn them on and off, but I can't seem to just make a call to create a
binding.
Re: Turning on key bindings in an editor [message #334082 is a reply to message #334065] Mon, 19 January 2009 13:15 Go to previous message
What are you trying to do (i.e. what behaviour do you expect your users
to see)? Normally, an RCP app can include the keys preference page and
allow users to change their keybindings (without having to code it
yourself). Changing keybindings is an expensive operation, and the API
is set up specifically to prevent people from using keybindings to
activate and de-activate commands.
> binding.
That's because the cost to fiddle around with bindings is much greater
than the cost to update commands with different handlers based on the
currently executing context (and that is what is designed into the system).
If you need to provide functionality like a keys preference page (and
can't include the preference page itself) then you need to code it like
the keys preference page (make changes to a local binding manager and
then save the bindings to the preference store). That's supported and
mostly API.
If you need to activate different behaviour for CTRL+8 depending on if
you are in an editor or a view, that's done by using
org.eclipse.ui.contexts and attaching different commands to those keys
in different contexts.
If you need the behaviour of a command to change depending on if you are
in an editor or a view (like copy in an editor gives text but copy in
the project explorer gives an IResource) the you use one keybinding, one
command, and multiple handlers.
Schemes are designed to never change. Context are designed to allow
different sets of keybindings to be swapped in depending on a major
change, like switching to a different view or editor. Handlers are
designed to be swapped in depending on the executing context.
PW
Paul Webster
Previous Topic:Custom ISelectionProvider and checkEnabled for Visibility of commands does not work properly
Next Topic:[PDE Build] Feature builds question
Current Time: Sat Aug 23 03:46:53 EDT 2025
Powered by FUDForum. Page generated in 0.05868 seconds
