Debugging DSL based on Xbase [message #1786403] |
Wed, 02 May 2018 17:17 |
Neeraj Bhusare Messages: 177 Registered: July 2009 Location: Canada |
I am trying to remote-debug a DSL that is based on Xbase. The breakpoints are hit, however, the source cannot be found. The project containing the DSL and the generated source is already added to the Edit source lookup path.
Trace files are generated automatically and I assume they are correct.
I am using Xtext 2.12.0
Any help/pointers are highly appreciated. Tx.
Twitter : @NeerajBhusare
Blog : https://nbhusare.github.io/
Best regards, Neeraj
Re: Debugging DSL based on Xbase [message #1786405 is a reply to message #1786403] |
Wed, 02 May 2018 17:57 |
(0) what are the exact symptoms of the issue
(1) did you make sure the classfile you use on the server contains all necessary information (e.g. as produced by DebugSourceInstallingCompilationParticipant)
(2) did you debug the source lookup e.g. org.eclipse.debug.core.sourcelookup.AbstractSourceLookupParticipant.findSourceElements(Object)
Twitter : @chrdietrich
FUDForum. Page generated in 0.03071 seconds
