Home » Eclipse Projects » Eclipse Platform » UI Thread
UI Thread [message #333972] Wed, 14 January 2009 14:48 Go to next message
I have code needs to determine if the current thread is UI thread or not,
since my plugin can not depend on any UI plugins, so I can not use
Display.getCurrent() to do so, is there any other way I can check the
thread? Will the UI thread in eclipse has higher priority?
Thanks for your help!
Re: UI Thread [message #333978 is a reply to message #333972] Thu, 15 January 2009 03:03 Go to previous messageGo to next message
UI Thread is not distinguishable from the other threads, so you cannot
determine easily whether the current thread is an UI thread.
The uber hardcore hack would be to examine the call stack and check
whether SWT classes or on it. In this case, there is a great chance that
you are on the UI thread.
But I suggest that you rethink your strategy and modify your code to not
depend on the UI thread or pass this information somehow from other
code, which depends on UI classes.
Benson Ning wrote:
> not, since my plugin can not depend on any UI plugins, so I can not use
Re: UI Thread [message #334004 is a reply to message #333978] Thu, 15 January 2009 10:26 Go to previous message
Originally posted by: szchaler.acm.org
Couldn't you just check Display.getCurrent(). The javadoc seems to say
that if it returns null you are not a UI thread...
Steffen
> Benson Ning wrote:
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to ECMDA-FA 2009, the 5th European Conference on
Model-Driven Architecture Foundations and Applications.
http://www.ecmda-fa.org/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Previous Topic:How to wait for launches to finish
Next Topic:Package Explorer shows no CVS infos after cvs-plugin was updated
Current Time: Sun Jul 13 05:23:04 EDT 2025
Powered by FUDForum. Page generated in 0.04043 seconds
