Home » Eclipse Projects » Eclipse Platform » How to wait for launches to finish
How to wait for launches to finish [message #333943] |
Wed, 14 January 2009 10:36  |
Originally posted by: szchaler.acm.org
I am programmatically triggering a launch using
DebugUITools.launch(launchConfig, "run"). This will create a new Job
that invokes the actual corresponding LaunchDelegate. In my code, I need
to do more work once this Job is done.
Unfortunately, it seems DebugUITools does not put this new Job into any
JobFamily. Therefore, I cannot use JobManager.join: Since the code I am
writing is in a Job itself, JobManager.join (null, monitor) deadlocks.
Is there any other way to wait for all Launches to finish?
Any hints would be greatly appreciated. Also, if this is the wrong
group, could you please direct me to the correct one?
Many thanks in advance,
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to ECMDA-FA 2009, the 5th European Conference on
Model-Driven Architecture Foundations and Applications.
http://www.ecmda-fa.org/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Re: How to wait for launches to finish [message #333952 is a reply to message #333943] |
Wed, 14 January 2009 11:38   |
Originally posted by: subs._nospam_consertum.com
Steffen Zschaler wrote:
> Steffen
Have you tried:
jobManager.join(ResourcesPlugin.FAMILY_MANUAL_BUILD,monitor) ;
or jobManager.join(ResourcesPlugin.FAMILY_AUTO_BUILD,monitor);
Derek
Re: How to wait for launches to finish [message #333966 is a reply to message #333952] |
Wed, 14 January 2009 12:50   |
Hi Derek,
Thanks for the quick reply.
Comments below
>> need to do more work once this Job is done.
>> any JobFamily. Therefore, I cannot use JobManager.join: Since the
>> code I am writing is in a Job itself, JobManager.join (null, monitor)
>> deadlocks. Is there any other way to wait for all Launches to finish?
>> Steffen
> Have you tried:
> or
No, these did not seem to make sense, as the jobs seem to be registered
without a family. Specifically, somewhere deep in Eclipse's logic
dealing with launch configurations, it will instantiate class Job
overriding only run(), but not belongsTo(). This means, this job will
not belong to any job family as far as I understand it.
I tried jobManager.join (null, monitor), but as I said above that
deadlocks as it essentially tries to join the job from which it calls
join...
Steffen
Re: How to wait for launches to finish [message #333968 is a reply to message #333966] |
Wed, 14 January 2009 13:19   |
Well, all I can see is this works for me, although I use
ResourcesPlugin.getWorkspace().build(buildType, monitor);
rather than DebugUITools
> Hi Derek,
> Comments below
>>> Hi,
>>> Steffen
>> Have you tried:
>> or
> join...
> Best regards,
> Steffen
Derek
Re: How to wait for launches to finish [message #333975 is a reply to message #333943] |
Wed, 14 January 2009 15:47   |
Can't you use ILaunchListener?
- Prakash
http://blog.eclipse-tips.com
"Steffen Zschaler" <szchaler@acm.org> wrote in message
news:gkl0qa$ve7$1@build.eclipse.org...
> DebugUITools.launch(launchConfig, "run"). This will create a new Job that
> invokes the actual corresponding LaunchDelegate. In my code, I need to do
> writing is in a Job itself, JobManager.join (null, monitor) deadlocks. Is
> Any hints would be greatly appreciated. Also, if this is the wrong group,
> Steffen
> Consider submitting to MiSE 2009, the 3rd International Workshop on Models
Re: How to wait for launches to finish [message #333982 is a reply to message #333968] |
Thu, 15 January 2009 04:47   |
Hi Derek,
Yes, I assume in that case it would work as you are actually triggering
a build job. Unfortunately, a launch is not a build job (launch is
Eclipse's term for the "Run As..." stuff).
Many thanks anyway,
Steffen
>> Hi Derek,
>> Comments below
>>>> Hi,
>>>> Job that invokes the actual corresponding LaunchDelegate. In my
>>>> code, I need to do more work once this Job is done.
>>>> monitor) deadlocks. Is there any other way to wait for all Launches
>>>> to finish?
>>>> Steffen
>>> Have you tried:
>>> or
>> registered without a family. Specifically, somewhere deep in
>> Eclipse's logic dealing with launch configurations, it will
>> instantiate class Job overriding only run(), but not belongsTo().
>> This means, this job will not belong to any job family as far as I
>> understand it.
>> join...
>> Best regards,
>> Steffen
Re: How to wait for launches to finish [message #333990 is a reply to message #333981] |
Thu, 15 January 2009 07:08  |
Thanks again for the hint. Yes, ILaunchesListener2 helped quite well. Of
course in the process I found out that the specific launch I was
interested in would trigger another asynchronous Job that didn't have a
family, but that I also had to wait for. But IJobChangeListener helped
me with that one, so eventually things seem to be working as I expect
them to.
Many thanks again for the pointers!
Steffen
> Hi Prakash,
> That sounds like an interesting idea. I've just had a look at
> ILaunchListener. I cannot immediately see how to do it, I guess I'll
> have to try some things and report back.
> Many thanks so far,
> Steffen
>> - Prakash
Current Time: Fri Jul 18 19:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.34893 seconds
