Home » Eclipse Projects » Eclipse Platform » Rearrange dropins folder fails
Rearrange dropins folder fails [message #333914] Tue, 13 January 2009 15:13 Go to next message
Hello!
I want to rearrange my dropins folder, but after rearranging the plugins
are not found anymore (the new layout is supported and works perfectly
in a fresh eclipse install).
By example:
I have my CDO Plugins installed in /dropins/eclipse/* (works fine) and
now move them to /dropins/cdo/eclipse/*.
But after doing that and restarting Eclipse (3.5M4) I get those errors
in the log:
ProvisionException
No repository found at
file:/C:/Users/superuser/eclipse/eclipse/eclipse_3.5_cdo_2/d ropins/cdo
If I unzip just a fresh Eclipse SDK and put the same directory layout in
the dropins folder everything works fine.
I tried to start Eclipse with the -clean argument, but this doesn't help.
Any suggestions how to rearranging the dropins folder?
Kai
Re: Rearrange dropins folder fails [message #333918 is a reply to message #333914] Tue, 13 January 2009 16:09 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
Kai Schlamp schrieb:
> Hello!
> By example:
> in the log:
> ProvisionException
> Best regards,
> Kai
Kai,
perhaps this helps you:
1. remove all plugins you want to re-arrange from dropins folder
2. start -clean and quit
3. put plugins into new location, use a folder name you never used
before inside dropins with this eclipse installation
4. start -clean
if you're in luck the plugins are there
ekke
Re: Rearrange dropins folder fails [message #333935 is a reply to message #333918] Wed, 14 January 2009 08:23 Go to previous messageGo to next message
Originally posted by: nospam_kowalskilee.gmail.com
>> Hello!
>> plugins are not found anymore (the new layout is supported and works
>> perfectly in a fresh eclipse install).
>> By example:
>> in the log:
>> ProvisionException
>> in the dropins folder everything works fine.
>> Best regards,
>> Kai
> Kai,
> 4. start -clean
> ekke
Hi ekke,
One pervasive question about p2 and dropins is why it doesn't seem to
completely "clean" just by using -clean.
I mean, why is this part of your step 3 necessary: "use a folder name
you never used before inside dropins with this eclipse installation".
I would have expected that if I did your step 1 and 2 (remove and
clean), then I could go ahead and use a folder name that I *have* used
before. Wouldn't it all be "clean" by that point?
--Lee Anne
Re: Rearrange dropins folder fails [message #333970 is a reply to message #333918] Wed, 14 January 2009 13:44 Go to previous messageGo to next message
Ok, your method worked ... thanks a lot.
But I find this procedure also a bit weird.
It would be much more straightforward if a simple -clean would be enough.
Shoud I create an enhancement request?
Kai
>> Hello!
>> By example:
>> in the log:
>> ProvisionException
>> Best regards,
>> Kai
> Kai,
> 4. start -clean
> ekke
Re: Rearrange dropins folder fails [message #334041 is a reply to message #333970] Fri, 16 January 2009 08:18 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=261344
> Best regards,
> Kai
>>> Hello!
>>> By example:
>>> and now move them to /dropins/cdo/eclipse/*.
>>> errors in the log:
>>> ProvisionException
>>> help.
>>> Best regards,
>>> Kai
>> Kai,
>> 4. start -clean
>> ekke
Previous Topic:Project nature icon displayed in the Navigator but not in the Project Explorer
Next Topic:[Common Navigator] possible memory problems w/ NavigatorContentDescriptorManager
Current Time: Thu Jul 17 09:08:52 EDT 2025
Powered by FUDForum. Page generated in 0.08805 seconds
