Home » Eclipse Projects » Eclipse Platform » Common Navigator DND
Common Navigator DND [message #333894] Tue, 13 January 2009 02:04 Go to next message
I am trying to add Drag and Drop support to my CN implementation.
Is there any tutorial / guide to get started on this particular issue?
I read on eclipse help that CommonDropAdapterAssistant and
CommonDragAdapterAssistant are the classes to start with but am a little
lost.
Any help would be appreciated.
Thank you,
~Adil.
Re: Common Navigator DND [message #333977 is a reply to message #333894] Wed, 14 January 2009 19:25 Go to previous messageGo to next message
Just wanted to provide an update.
1.
I added dragAssistant to my viewer Extension and supplied the class.
This class is a subclass of CommonDragAdapterAssistant
So when i start to drag, the getSupportedTransferTypes() method is called.
The problem now is setDragData() method is never called where i could
set the get hold of the data to be dragged.
Any help would be good. Thanks.
~Adil.
Adil Fulara wrote:
> lost.
> Thank you,
> ~Adil.
Re: Common Navigator DND [message #334019 is a reply to message #333977] Thu, 15 January 2009 19:06 Go to previous messageGo to next message
What are you trying to accomplish by adding the drag assistant?
In general, if you are using the LocalSelectionTransferType (which can
cover anything selected by the navigator), then you don't need to do
anything on the drag side.
You only need to add the special drag support if you want a different
transfer type.
Francis
(ps - please reply to the newsgroup, but you may copy me on the reply so
I get it quickly).
> 1.
> ~Adil.
> Adil Fulara wrote:
>> little lost.
>> Thank you,
>> ~Adil.
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
[Common Navigator]Re: Common Navigator DND [message #334023 is a reply to message #334019] Thu, 15 January 2009 19:25 Go to previous messageGo to next message
I am actually trying to drag an object from one common navigator and
drop it onto another common navigator.
I thought at the drag side, we need to get hold of the drag object and
have a reference to it on the drop side. Hence i added the dragAssistant
and dropAssitant.
So as per your reply, if i understand correctly, i just need to add a
dropAssistant at the receiving side and handle the drop?
~Adil.
> transfer type.
> Francis
> I get it quickly).
>> 1.
>> called.
>> ~Adil.
>> Adil Fulara wrote:
>>> Hi,
>>> little lost.
>>> Thank you,
>>> ~Adil.
Re: [Common Navigator]Re: Common Navigator DND [message #334027 is a reply to message #334023] Thu, 15 January 2009 22:05 Go to previous messageGo to next message
Yes, that's all you should need. And if you are using resources, then
you don't even need that.
> and dropAssitant.
> ~Adil.
>> transfer type.
>> Francis
>> so I get it quickly).
>>> 1.
>>> called.
>>> ~Adil.
>>> Adil Fulara wrote:
>>>> Hi,
>>>> little lost.
>>>> Thank you,
>>>> ~Adil.
Re: [Common Navigator]Re: Common Navigator DND [message #334029 is a reply to message #334027] Thu, 15 January 2009 22:57 Go to previous message
Great. This is awesome.
It works fine. Thanks very much Francis.
Guess the SWT DND tutorial took me on the wrong path and confused me.
I now can handle DnD in my views.
~Adil.
>> dragAssistant and dropAssitant.
>> ~Adil.
>>> can cover anything selected by the navigator), then you don't need to
>>> do anything on the drag side.
>>> transfer type.
>>> Francis
>>>> 1.
>>>> called.
>>>> could set the get hold of the data to be dragged.
>>>> ~Adil.
>>>> Adil Fulara wrote:
>>>>> Hi,
>>>>> little lost.
>>>>> Thank you,
>>>>> ~Adil.
Previous Topic:superseding existing label/content providers in the common navigator framework
Next Topic:Error Attaching Source beginRule does not match outer scope rule ...
Current Time: Fri Jul 18 13:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.18386 seconds
