Exception when doing drag-drop into a Texteditor [message #333816] |
Wed, 07 January 2009 05:28  |
[I apologise for the duplicate post, but I decided the SWT was probably the
wrong group for this.]
I have a plain old TextEditor (org.eclipse.ui.editors.text) that I am using
in a multi-page editor within and RCP application. This is based on Eclipse
3.4 SR1. Drag and drop support is enabled. When I try to drop some text into
the editor I get the first exception below. When dragging text out I get the
second.
I am missing an initialisation step? I have read through the documentation
and Googled, but I find nothing relevant.
Many thhanks,
Joel
org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl$1.d ragLeave(EditorS
iteDragAndDropServiceImpl.java:104)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :70)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1561)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1570)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 360)
org.eclipse.swt.dnd.DropTarget.dragTrackingHandler(DropTarge t.java:435)
org.eclipse.swt.dnd.DropTarget.DragTrackingHandler(DropTarge t.java:260)
at org.eclipse.swt.internal.carbon.OS.ReceiveNextEvent(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3048)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.swt.dnd.DropTarget.DragTrackingHandler(DropTarge t.java:251)
at org.eclipse.swt.internal.carbon.OS.TrackDrag(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:351)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :166)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3482)
at org.eclipse.swt.widgets.Control.sendTrackEvents(Control.java :3024)
at org.eclipse.swt.widgets.Control.actionProc(Control.java:122)
at org.eclipse.swt.widgets.Display.actionProc(Display.java:362)
at org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(Nati ve
Method)
at org.eclipse.swt.widgets.Widget.kEventControlTrack(Widget.jav a:1106)
at org.eclipse.swt.widgets.Control.kEventControlTrack(Control.j ava:2097)
at org.eclipse.swt.widgets.Widget.controlProc(Widget.java:375)
at org.eclipse.swt.widgets.Display.controlProc(Display.java:862 )
at org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(Na tive
Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3051)
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme & ORMF
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf/]
Re: Exception when doing drag-drop into a Texteditor [message #333831 is a reply to message #333829] |
Wed, 07 January 2009 16:57   |
[Sorry I forgot to add RCP into the distribution list].
On 07/01/2009 21:41, in article C58AD218.163BE%Joel.Rosi-Schwartz@Etish.org,
"Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote:
I have made some progress with narrowing this down.
1) In the Eclipse PDE Multi-page editor example the drag-n-drop works fine
in the text editor page.
2) In an RCP application using the standard standalone Texteditor the
drag-n-drop works fine.
3) Adding the MultiPageEditor class from the examaple into the RCP
application creates the problem. It throws the exceptions below.
I can open a bug and add my test plug-in to demonstrate this if this is an
Eclipse RCP bug.
The problem that I have is that I have a delivery date looming and this
functionality is central the application.
Assistance would be very much appreciated.
Many thanks,
Joel
> On 07/01/2009 10:28, in article C58A3450.15371%Joel.Rosi-Schwartz@Etish.org,
>> second.
>> Many thhanks,
>> Joel
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Method)
>> Method)
>> at
>> at
Joel Rosi-Schwartz
Re: Exception when doing drag-drop into a Texteditor [message #333851 is a reply to message #333831] |
Fri, 09 January 2009 07:50   |
I have diagnosed the cause of the problem. Adding the org.eclipse.ui.editors
bundle into an RCP application prevents the Texteditor from functioning
properly in regards to DND.
A workaround is to add the following to ApplicationWorkbenchWindowAdvisor
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.configureEditorAreaDropListener(
new EditorAreaDropAdapter(
configurer.getWindow()));
I will file a bug report over the weekend and add a link to in this thread.
Joel
On 07/01/2009 21:57, in article C58AD5E6.169A1%Joel.Rosi-Schwartz@Etish.org,
> Eclipse RCP bug.
> Many thanks,
> Joel
>>> Hi,
>>> second.
>>> Many thhanks,
>>> Joel
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Method)
>>> Method)
>>> at
>>> at
Joel Rosi-Schwartz
Re: Exception when doing drag-drop into a Texteditor [message #333855 is a reply to message #333844] |
Fri, 09 January 2009 11:52  |
Yes, I will do it over the weekend and post the Bug # back to the newsgroup.
Joel
On 08/01/2009 18:37, in article gk5h5d$jgc$1@build.eclipse.org, "Boris
Bokowski" <Boris_Bokowski@ca.ibm.com> wrote:
> Would you be able to file a bug against Platform UI with an attached example
> plugin to reproduce?
> Boris
> "Joel Rosi-Schwartz" <Joel.Rosi-Schwartz@Etish.org> wrote in message
> news:C58AD218.163BE%Joel.Rosi-Schwartz@Etish.org...
>> fine
>> Eclipse RCP bug.
>> Many thanks,
>> Joel
>>> the
>>> Hi,
>>> using
>>> Eclipse
>>> into
>>> the
>>> second.
>>> documentation
>>> Many thhanks,
>>> Joel
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Method)
>>> at
>>> at
>>> Method)
>>> at
>>> at
>>> at
>>> at
>> Joel Rosi-Schwartz
Joel Rosi-Schwartz
FUDForum. Page generated in 0.14503 seconds
