Home » Eclipse Projects » Eclipse Platform » Plugin configuration by start file
Plugin configuration by start file [message #333785] Mon, 05 January 2009 16:15 Go to next message
Hallo,
Is there a way to start eclipse with a predefined set of plugins and
perspectives?
I would start eclipse for Java with other plugins and perspectives than
for PHP. While I work with Java I don't need the plugins for PHP so they
can be inactive.
Is that possible to configure the active plugins by start file or the
like?
Re: Plugin configuration by start file [message #333787 is a reply to message #333785] Mon, 05 January 2009 16:47 Go to previous messageGo to next message
Originally posted by: coolsnoopy.gmx.net
Christian wrote:
> Hallo, Is there a way to start eclipse with a predefined set of plugins
> and perspectives?
> can be inactive. Is that possible to configure the active plugins by
> start file or the like?
2 possibilities here:
a) different perspectives
use 2 different workspaces: e.g. "workspace-php" and "workspace-java".
By the way: avoid blanks in workspace-folder names, some tools/plugins
work improper else...
b) different / other plugins
No really simple way: you just have do install eclipse twice (or even
more times). I do the same for very different projects. That may end up
in 2 or 3 installations. The problem is to transfer settings that should
be the same in every installation. But it's possible.
Re: Plugin configuration by start file [message #333793 is a reply to message #333785] Tue, 06 January 2009 01:11 Go to previous message
Ideally you shouldn't be worrying about this. If you have not done any Java
stuff (like building a project, launching a java app, invoking a jdt
action) - the jdt.* plugins should not be loaded at all. Eclipse is designed
that way! Most of the UI contributions do not require the plugin to be
loaded. Its just the plugin.xml and the manifest.mf that needs to be read to
construct the UI
- Prakash
http://blog.eclipse-tips.com
"Christian " <christian-usenet@web.de> wrote in message
news:af52c47ca4e851da110cb529c466ae50$1@www.eclipse.org...
> and perspectives?
Previous Topic:Re: Generic tableviewer sorter
Next Topic:Meaning of decoration of files in tabs of texteditor
Current Time: Mon Jul 14 13:38:14 EDT 2025
Powered by FUDForum. Page generated in 0.04779 seconds
