Re: OHF Bridge Installation [message #33867] |
Thu, 04 October 2007 13:06 |
Daniel,
I've added the OHF newsgroup to the "to" list of the reply. It's best
to ask your questions there. I see a recent question that sounds quite
similar so have a look at the answer for that one.
Daniel Silva wrote:
> I'm a starter user of OHF.
> My first step is install the OHF Bridge, but Im having difficulties in
> doing it.
> I follow the installation guide (at
> http://www.eclipse.org/ohf/components/bridge/install.php), but in the end
> of process the web service is not available
> (http://localhost:8080/bridge/services/ohf-bridge?wsdl) (the port is
> correctly defined).
> For a better overview I explain what Im doing:
> - I have Tomcat 5.5 installed. I stop it and delete the folder Catalina
> from .../Tomcat 5.5/work directory;
> - I don't know if i got the correct OHF Bridge Installation Package
> (is it
> "org.eclipse.ohf.bridge-install_0.2.0M2-incubation.zip"? There are other
> pre-requisites? );
> - I download the "org.eclipse.ohf.bridge-install_0.2.0M2-incubation.zip"
> and extract the files (obtain 2 folders (conf and webapps) and 2 files
> (notice and epl-v10));
> - Then, I copy the files from conf folder to .../Tomcat 5.5/conf and the
> file bridge.war from webapps to .../Tomcat 5.5/webapps
> - Finally I start Tomcat again and test the web service but it aren't
> there.
> Can you please give me some help?
> Thanks in advance,
> Daniel
FUDForum. Page generated in 0.02988 seconds
