Home » Eclipse Projects » Eclipse Platform » artifacts.xml file is misplaced when using -configuration parameter
artifacts.xml file is misplaced when using -configuration parameter [message #333765] Sat, 03 January 2009 16:09 Go to next message
My system is Windows Vista Ultimate.
eclipse.ini contains:
-configuration
@user.home/AppData/Roaming/eclipse-3.4.1/configuration
This directory is correctly created on first startup of eclipse.exe.
However there is a second directory created
"@user.home/AppData/Roaming/eclipse" (note that the version is missing)
that contains only the file artifacts.xml.
Am I missing something or is it a bug?
-- Frank
Re: artifacts.xml file is misplaced when using -configuration parameter [message #333766 is a reply to message #333765] Sat, 03 January 2009 17:00 Go to previous message
The problem was that
eclipse-installation-dir/configuration/config.ini#eclipse.p2 .data.area
pointed to @config.dir (as default).
-- Frank
Previous Topic:Launching Java process from a plugin
Next Topic:Eclipse crashes after having started with the -clean option
Current Time: Sun Nov 23 10:48:22 EST 2025
Powered by FUDForum. Page generated in 0.03559 seconds
