Home » Eclipse Projects » Subversive » Couldn't create new project from SVN!
Couldn't create new project from SVN! [message #33865] Fri, 19 September 2008 02:46 Go to next message
Hi All,
I tried many times to create new project from SVN, but I got the
following error message:
SVN: '0x00400006: Validate Repository Location' operation finished with
error: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available or install and select pure Java Subversion connector from the
plug-in connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
Could you please help me?
Note:
Eclipse Version: 3.4.0
Build id: I20080617-2000
update manager link:
http://download.eclipse.org/technology/subversive/0.7/update -site/
Best Regards تحياتي
Muhammad Bashir Al-Noimi محمد بشير النعيمي
My Blog مدونتي
http://mbnoimi.net/
Re: Couldn't create new project from SVN! [message #33914 is a reply to message #33865] Fri, 19 September 2008 03:28 Go to previous message
M. Bashir Al-Noimi wrote:
> Hi All,
> Note:
I got it,
You can fix this problem by adding missing binaries from the following link:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
Best Regards تحياتي
My Blog مدونتي
http://mbnoimi.net/
Previous Topic:Subversive build 1.0.0
Next Topic:polarion.com down?
Current Time: Tue Jul 22 17:51:33 EDT 2025
Powered by FUDForum. Page generated in 0.02532 seconds
