Home » Eclipse Projects » Eclipse Platform » Deselecting a combo with JFace Databinding
Deselecting a combo with JFace Databinding [message #333733] Tue, 30 December 2008 08:24 Go to next message
What is the best way to clean a combo or comboviewer with databinding
setting the model value? There is a good snipet for it somewhere? I searched
the snippets and examples and could not find anything.
Actually, using a ComboViewer, I am just able to do this calling the
deselectAll method. If I set the variable on the model to -1 (out of range
values) it is not working.
Thanks for any help.
Marcelo
Re: Deselecting a combo with JFace Databinding [message #333737 is a reply to message #333733] Tue, 30 December 2008 09:16 Go to previous messageGo to next message
On 12/30/2008 8:24 AM, Marcelo Alcantara wrote:
I would try setting the model value to null.
Hope this helps,
Eric
Re: Deselecting a combo with JFace Databinding [message #333740 is a reply to message #333737] Tue, 30 December 2008 09:30 Go to previous messageGo to next message
Or setting the ComboViewer-Selection to StructuredSelection.EMPTY.
Tom
>> searched
>> range
> Hope this helps,
> Eric
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Deselecting a combo with JFace Databinding [message #333797 is a reply to message #333740] Tue, 06 January 2009 07:35 Go to previous message
Tom/Eric,
Thanks.
I was making the bind with the combo widget (inside the combo viewer) and
not the combo viewer itself. I changed to use the
ViewerObservable.observeSingleSelection and the set(null) cleared the combos
without problems.
Marcelo
"Tom Schindl" <tom.schindl@bestsolution.at> escreveu na mensagem
news:gjdban$qad$1@build.eclipse.org...
> Tom
>>> Hi,
>>> searched
>>> range
>> Hope this helps,
>> Eric
Previous Topic:Eclipse Platform UI testing
Next Topic:Stretching the section vertically
Current Time: Sun Aug 31 10:43:58 EDT 2025
Powered by FUDForum. Page generated in 0.02395 seconds
