Home » Eclipse Projects » Eclipse Platform » Preference page
Preference page [message #333692] Tue, 23 December 2008 12:41 Go to next message
I want to display only Editors under General in preference page.
How would I do this?
Re: Preference page [message #333697 is a reply to message #333692] Tue, 23 December 2008 20:47 Go to previous messageGo to next message
My way to do that (only showing some of the Contributed Preference
Pages) was implementing a handler that opens a preference dialog that
only shows the IDs of the preference pages I want
Opening the dialog yourself you can by providing a String[] instance to
control which preference pages are shown.
public Object execute(ExecutionEvent event) throws ExecutionException {
IWorkbenchWindow window =
HandlerUtil.getActiveWorkbenchWindowChecked(event);
PreferenceDialog dialog = PreferencesUtil.createPreferenceDialogOn(
window.getShell(), null, getValidPreferenceIDs(), null);
dialog.open();
return null;
May be there is a better solution... though this one worked for me just
fine.
Christian
Re: Preference page [message #333698 is a reply to message #333697] Tue, 23 December 2008 23:35 Go to previous messageGo to next message
How the above will be implemented?
Re: Preference page [message #333706 is a reply to message #333698] Wed, 24 December 2008 07:56 Go to previous messageGo to next message
extend an abstract Handler ... and implement the method as seen above..
example for getting the String array:
* remove the unwanted preferences..
private static String[] getValidPreferenceIDs() {
List<String> validIds = new ArrayList<String>();
IConfigurationElement[] ce=
Platform.getExtensionRegistry().getConfigurationElementsFor( "org.eclipse.ui.preferencePages");
for (IConfigurationElement cele:ce) {
String s= cele.getAttribute("id");
validIds.add(s);
validIds.remove("org.eclipse.help.ui.browsersPreferencePage ");
validIds.remove("org.eclipse.help.ui.contentPreferencePage");
validIds.remove(" org.eclipse.update.internal.ui.preferences.MainPreferencePag e ");
return validIds.toArray(new String[0]);
Define a command in the plugin.xml. Ans use this handler as a default
handler.
Now you can either add the command to some menu or programmtically call it.
Christian
Re: Preference page [message #333712 is a reply to message #333706] Wed, 24 December 2008 14:05 Go to previous messageGo to next message
As I am very new to plugin development, I am not able to understand the
solution.
Could you please explain more, or please tell step by steps.
Re: Preference page [message #333715 is a reply to message #333712] Thu, 25 December 2008 08:42 Go to previous message
Anand,
You'll really need to take some more initiative and go learn the
background information.
> the solution.
Previous Topic:Form problems.
Next Topic:Path in problem view
Current Time: Mon Jul 21 21:37:54 EDT 2025
Powered by FUDForum. Page generated in 0.25246 seconds
