Home » Eclipse Projects » Eclipse Platform » 3.4 installation as a target platform
3.4 installation as a target platform [message #333635] Thu, 18 December 2008 18:06 Go to next message
My team is in the habit of checking in our target platform into CVS so
that we are all building against a known platform.
I've always just taken an Eclipse EPP package, unzipped it, added the
other required features and plugins, and then checked that in. This
worked well while we were building against Europa.
But it seems that p2 complicates things a bit. I've noticed that there
seems to be machine-specific stuff (ie, absolute paths) in the
configuration/ and p2/ directories of the target platform, especially
after I run it to pick up something new I've added (or removed) from the
dropins/ directory.
So my question is, what should be excluded from check-in when a Ganymede
installation is used as the target platform?
TIA,
Eric
Re: 3.4 installation as a target platform [message #333637 is a reply to message #333635] Thu, 18 December 2008 19:46 Go to previous messageGo to next message
> dropins/ directory.
There has been a lot of bugs around path issues that were resolved
recently as of 3.5M4... I know that's not the greatest thing to say but
is updating an option for you?
I would ask this question on the Equinox newsgroup where the p2 team
lingers.
~ Chris
Re: 3.4 installation as a target platform [message #333644 is a reply to message #333637] Fri, 19 December 2008 10:04 Go to previous messageGo to next message
>> the dropins/ directory.
>> Ganymede installation is used as the target platform?
> lingers.
No, going to 3.5 is not an option right now. I've only recently
convinced the team to go to 3.4 because our product is now being based
on it :-(
I've copied the equinox group to this thread, so hopefully the p2 team
can provided some insight.
Eric
Re: 3.4 installation as a target platform [message #333651 is a reply to message #333644] Fri, 19 December 2008 12:47 Go to previous messageGo to next message
I could be wrong but I think most of the path issues are fixed in 3.4.1.
I just checked my config.ini to make sure but I do not see any absolute
paths. 3.4.1 is released so it should be less risk for you're team.
Re: 3.4 installation as a target platform [message #333653 is a reply to message #333651] Fri, 19 December 2008 13:42 Go to previous messageGo to next message
> absolute paths. 3.4.1 is released so it should be less risk for you're
> team.
I am using 3.4.1
The absolute paths appear to be confined mostly to these directories,
which I'm assuming are OK to leave out of the target platform when I
check it in; I'm really looking for confirmation that it will not come
up to bite me in the future, or if there is any other stuff that can
safely be removed from the installation and still have it work as a
target platform.
configuration\org.eclipse.osgi\
p2\org.eclipse.equinox.p2.director\
p2\org.eclipse.equinox.p2.engine\profileRegistry\PlatformPro file.profile\
Eric
[bump] [p2] Re: 3.4 installation as a target platform [message #333694 is a reply to message #333653] Tue, 23 December 2008 15:20 Go to previous message
>> team.
> I am using 3.4.1
> target platform.
It appears this does not work. If the PlatformProfile.profile directory
is missing, p2 fails miserably with no indication to the user. You click
Software Updates... from the menu and it just does nothing. There are
NPEs in the error log, but nothing in terms of user feedback.
The worst part of all this is that it seems it is impossible now to use
a 3.4 installation checked in to source control as a target platform for
a team to share! That was a good use case in 3.2 and 3.3; now I can't
figure out how to reach the goal of a shared target platform.
Is there any option at this point (3.5 is not an option)? The storage of
and reliance on absolute paths looks to be a showstopper here...
Anyone from the p2 or PDE teams...?
Eric
Previous Topic:How to best migrate projects from one workspace to another?
Next Topic:Duplicate DocumentEvent firing
Current Time: Thu Jul 17 21:54:12 EDT 2025
Powered by FUDForum. Page generated in 0.29572 seconds
