Home » Eclipse Projects » Eclipse Platform » p2: problem with permissions.properties on linux
p2: problem with permissions.properties on linux [message #333630] Thu, 18 December 2008 16:29
Hi all,
I'm using the 'permissions.properties' file to set +x attribute to the
binary files during plugin installation. The file content is similar to
permissions.executable = myengine/bin/*.*,...
It worked fine on 3.2 and 3.3 (well, I had to type '*.*' instead of just
'*' to avoid the bug #190932; but it worked).
Suddenly, it stopped working in 3.4 (last tested using 3.4.1) - it
simply installs the plugin, but does not change the permissions.
The 'migration from 3.3 to 3.4' document says that old update sites are
installed the same way as it was done before. Any clue - what might
happen, and how to fix it?
thanks
/Sergey
Previous Topic:Mixing Platform Command and Action Set frameworks
Next Topic:How can I change the location where the project files are stored?
Current Time: Tue Jul 22 08:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.04457 seconds
