Register EPackage in Xcore programatically in Standalone [message #1782143] |
Mon, 19 February 2018 12:23 |
I am trying to access the EPackage inside an XCore, so I can register it and load models that conform to the metamodel defined using xcore. This should work both when invoked from an Eclipse as in standalone (i.e. register the metamodel from a non-eclipse java application)
So far I have done:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap(true));
resourceSet.getPackageRegistry().put(XcorePackage.eINSTANCE.getNsURI(), XcorePackage.eINSTANCE);
Resource metamodel = resourceSet.createResource(locationURI);
metamodel.load(Collections.EMPTY_MAP);
EPackage ePackage = (EPackage)EcoreUtil.getObjectByType(metamodel.getContents(), EcorePackage.Literals.EPACKAGE);
Currently I am getting an exception in the createResource call:
java.lang.NoClassDefFoundError: org/eclipse/xtext/ui/shared/SharedStateModule
at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.getSharedStateModule(XcoreActivator.java:92)
at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.createInjector(XcoreActivator.java:64)
at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.getInjector(XcoreActivator.java:55)
at org.eclipse.emf.ecore.xcore.ui.XcoreExecutableExtensionFactory.getInjector(XcoreExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.emf.ecore.plugin.RegistryReader$PluginClassDescriptor.createInstance(RegistryReader.java:167)
at org.eclipse.emf.ecore.plugin.RegistryReader$ResourceFactoryDescriptor.createFactory(RegistryReader.java:189)
at org.eclipse.emf.ecore.resource.impl.ResourceFactoryRegistryImpl.convert(ResourceFactoryRegistryImpl.java:92)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$2.delegatedGetFactory(ResourceSetImpl.java:458)
at org.eclipse.emf.ecore.resource.impl.ResourceFactoryRegistryImpl.getFactory(ResourceFactoryRegistryImpl.java:144)
at org.eclipse.emf.ecore.resource.impl.ResourceFactoryRegistryImpl.getFactory(ResourceFactoryRegistryImpl.java:85)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:431)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:423)
at org.eclipse.epsilon.emc.emf.EmfUtil.registerXcore(EmfUtil.java:212)
at org.eclipse.epsilon.emc.emf.EmfUtil.registerXcore(EmfUtil.java:201)
at org.eclipse.epsilon.emf.dt.EmfRegistryManager.registerMetamodel(EmfRegistryManager.java:142)
at org.eclipse.epsilon.emf.dt.EmfRegistryManager.addMetamodel(EmfRegistryManager.java:128)
at org.eclipse.epsilon.emf.dt.RegisterMetamodelHandler.execute(RegisterMetamodelHandler.java:40)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:433)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:454)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem$3.handleEvent(AbstractContributionItem.java:482)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
The stack trace also suggests that in a standalone scenario I would need to add some "ui" dependencies, even though my java application does not do any UI per se.
Thanks for any info or pointers.
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
Re: Register EPackage in Xcore programatically in Standalone [message #1782152 is a reply to message #1782145] |
Mon, 19 February 2018 15:03 |
Hi Ed,
Thanks for the information.
Yes, you are right that was from an Eclipse instance. I try the standalone setup for plain Java.
In the case of a UI present, any pointers on the error? My plugin has a dependency on xcore, but not on xtext. Do I need to also depend on xtext (and any other plugins?).
Kinori Tech
FUDForum. Page generated in 0.03573 seconds
