Home » Eclipse Projects » Eclipse Platform » suppress warnings about @SuppressWarnings("PMD")
suppress warnings about @SuppressWarnings("PMD") [message #333596] Thu, 18 December 2008 03:29
I am using the eclipse PMD plugin (a static source code analyser with
sophisticated rule sets) with Eclipse Java edition. It has a feature where
I can use the standard Java compiler annotation of @SuppressWarnings
passing in the rules to ignore as @SuppressWarnings("PMD.ruleX").
My problem is that eclipse then puts a warning that it does not understand
this annotation. If you are seeking to tune your rule set and have a zero
tolerance to any warnings these spurious warnings are a wart on the nose.
Is there any way to configure eclipse to ignore these static analysis
annotations?
Thanks.
Previous Topic:How to install plugins in a specialized location for Eclipse 3.4
Next Topic:Project Explorer Drop problem
Current Time: Sun Aug 03 02:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.02716 seconds
