Home » Eclipse Projects » Eclipse Platform » Using scanner and text framework without a widget
Using scanner and text framework without a widget [message #333491] Mon, 15 December 2008 11:09
Originally posted by: bsv.datatel.com
I have a source code viewer built on top of a scanner that extends
RuleBasedScanner.
Is it possible to run the scanner against an IDocument, have it inject
tokens that hold TextAttribute data, and then walk over that data and
spit out, say, an HTML file? That would be instead of handing it off to
a StyledText widget for display.
I'm trying to capture the formatted code in a portable non-widget format
for embedding in a report (using BIRT).
Has anyone ever done anything like this?
Ben
Previous Topic:Update layout on AbstractOverridableTabListPropertySection
Next Topic:building update site
Current Time: Thu Jul 17 21:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.02900 seconds
