Home » Eclipse Projects » Eclipse Platform » rcp and plugin startup code
rcp and plugin startup code [message #333485] Mon, 15 December 2008 05:42 Go to next message
what is to best way to run initializing code in a rcp application and in
plugins?
I read that IStartup should not be used, so what is the prefered way?
For example I like to contribute a menu with IMenuService. This menu
should be avaible after startup.
Should I start this via a extension point from my rcp and if so, from
which method I should invoke this? Or should I start this via the plugins
activator (inside a WorkbenchJob)?
Any hints are welcome!
regards,
Markus
Re: rcp and plugin startup code [message #333499 is a reply to message #333485] Mon, 15 December 2008 14:34 Go to previous message
Markus Schindler wrote:
> Hello,
> plugins?
Well, normally you would simply contribute via org.eclipse.ui.menus ...
when it is necessary to instantiate it (as with a user showing a menu)
eclipse will). Why is this form of delayed startup not sufficient?
> plugins activator (inside a WorkbenchJob)?
Within an RCP app you can always execute code in the WorkbenchAdvisor or
WorkbenchWindowAdvisor pre and post methods, so you don't usually need
to start up anything.
org.eclipse.ui.startup can be used if code really needs to start up (it
is run after that last post-startup advisor code) but usually you take
care to only run framework level startup (the less UI code you have in
an early startup plugin, the better). We generally discourage it since
early startup plugins are not good IDE citizens.
Paul Webster
Previous Topic:Actions and command handlers
Next Topic:Edit menu options do not get enabled for all views
Current Time: Mon Sep 01 02:35:34 EDT 2025
Powered by FUDForum. Page generated in 0.06096 seconds
