| Configuration of XSD/WSDL errors in Eclipse [message #333480] |
Sat, 13 December 2008 09:59  |
in Eclipse 3.2.2 in xsd and wsdl files e. g. following errors are indicated:
The markup in the document following the root element must be well-formed.
WSDL: The body part does not have a type defined and has been specified for
a SOAP body with its use encoded. When use is encoded on a SOAP body, all
parts defined must only contain a valid type.
XSD: An element reference may only have an id, minOccurs, or maxOccurs
XSD: Attribute reference
'http://schemas.xmlsoap.org/soap/encoding/#arrayType' is unresolved
.... and others
How, i. e. where can the error level of these errors be configured in
Eclipse, that they are indicated either as warning only or even be ignored
(such as other error cases)?
I tried to reach this by switching off all checkboxes at "WSDL Validator"
and "XML Schema Validator" at the rubric Validation in
Window/Preferences... - but no changes were observed, so these messages
still appeared as errors.
Thomas Wiedmann
| Re: Configuration of XSD/WSDL errors in Eclipse [message #333481 is a reply to message #333480] |
Sat, 13 December 2008 10:42   |
Thomas,
It's probably best to ask on the WTP newsgroup, though it sounds like
your schemas at least are not well-defined and ought to be fixed; after
all, hiding error messages doesn't make errors themselves go away...
Thomas Wiedmann wrote:
> Hello,
> indicated:
> well-formed.
> specified for a SOAP body with its use encoded. When use is encoded on
> a SOAP body, all parts defined must only contain a valid type.
> ... and others
> ignored (such as other error cases)?
> Validator" and "XML Schema Validator" at the rubric Validation in
> messages still appeared as errors.
> Thomas Wiedmann
| Re: Configuration of XSD/WSDL errors in Eclipse [message #333482 is a reply to message #333480] |
Sat, 13 December 2008 18:49  |
> Hello,
Short answer you can't yet. I think their is an open bug request for
this but I'm not positive on that.
Dave
FUDForum. Page generated in 0.04509 seconds
