Mosquitto failing to start [message #1780307] |
Fri, 19 January 2018 17:47 |
luis calzada Messages: 1 Registered: January 2018 |
Junior Member |
Hi, im new to using mosquitto and mqtt. Im trying to make a raspberry pi as a gateway so that my sensors communicate to it using mqtt.
I installed Mosquitto to achieve this, the installation appears to be succesful but when i try to test it using two mosquitto clients, the message is never received. If i run:
sudo service mosquitto status
i get this:
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset
Active: failed (Result: signal) since Fri 2018-01-19 10:55:28 CST; 25min ago
Docs: man:mosquitto(8)
https://mosquitto.or g/
Process: 2825 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (
Main PID: 2825 (code=killed, signal=SEGV)
Jan 19 10:55:27 raspberrypi systemd[1]: mosquitto.service: Failed with result 's
Jan 19 10:55:28 raspberrypi systemd[1]: mosquitto.service: Service hold-off time
Jan 19 10:55:28 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Jan 19 10:55:28 raspberrypi systemd[1]: mosquitto.service: Start request repeate
Jan 19 10:55:28 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
Jan 19 10:55:28 raspberrypi systemd[1]: mosquitto.service: Unit entered failed s
Jan 19 10:55:28 raspberrypi systemd[1]: mosquitto.service: Failed with result 's
What can i do to fix this? is there any course o tutorial i can read to learn more? thanks
FUDForum. Page generated in 0.02681 seconds
