Home » Eclipse Projects » Eclipse Platform » SimpleContentProposalProvider with LabelProvider gives a wrong proposal text
SimpleContentProposalProvider with LabelProvider gives a wrong proposal text [message #333432] Thu, 11 December 2008 02:21 Go to next message
Hello!
I making a content assist for a text field.
private void createContentAssist(Text field) {
ControlDecoration dec = new ControlDecoration(field, SWT.CENTER
| SWT.LEAD);
dec.setImage(getContentAssistDecoration().getImage());
dec.setDescriptionText(getContentAssistDecoration().getDescr iption()
+ "(" + CONTENT_ASSIST_KEYSTROKE + ")");
dec.setShowOnlyOnFocus(true);
char[] autoActivationCharacters = new char[] { '#', '(' };
KeyStroke keyStroke = null;
try {
keyStroke = KeyStroke.getInstance(CONTENT_ASSIST_KEYSTROKE);
} catch (ParseException e) {
ContentProposalAdapter adapter = new ContentProposalAdapter(field,
new TextContentAdapter(), new SimpleContentProposalProvider(
toArrayOfStrings(getTreesList())), keyStroke,
autoActivationCharacters);
adapter.setLabelProvider(getLabelProvider());
private static final String CONTENT_ASSIST_KEYSTROKE = "Ctrl+Space";
private FieldDecoration getContentAssistDecoration() {
return FieldDecorationRegistry.getDefault().getFieldDecoration(
FieldDecorationRegistry.DEC_CONTENT_PROPOSAL);
private String[] toArrayOfStrings(Object[] objects) {
String[] result = new String[objects.length];
for (int i = 0; i < objects.length; i++)
result[i] = objects[i].toString();
return result;
and when launching it gives me icons in content assist (that's why i
needed a LabelProvider) and wrong text, something like:
org.eclipse.jface.fieldassist.SimpleContentProposalProvider$1@4ca6b6
org.eclipse.jface.fieldassist.SimpleContentProposalProvider$1@16b904d
org.eclipse.jface.fieldassist.SimpleContentProposalProvider$1@cec78d
getText in my LabelProvider uses toString().
this happens because of this code:
public class ContentProposalAdapter {
* Get the string for the specified proposal. Always return a String of
* some kind.
private String getString(IContentProposal proposal) {
if (proposal == null) {
return EMPTY;
if (labelProvider == null) {
return proposal.getLabel() == null ? proposal.getContent()
: proposal.getLabel();
return labelProvider.getText(proposal);
proposal is defined in SimpleContentProposalProvider like that:
public class SimpleContentProposalProvider implements
IContentProposalProvider {
* Make an IContentProposal for showing the specified String.
private IContentProposal makeContentProposal(final String proposal) {
return new IContentProposal() {
public String getContent() {
return proposal;
public String getDescription() {
return null;
public String getLabel() {
return null;
public int getCursorPosition() {
return proposal.length();
so this proposal doesn't return content in toString().
i've bypassed this by changing a getText() in my LabelProvider to:
public String getText(Object element) {
if (element instanceof IContentProposal) {
IContentProposal proposal = ((IContentProposal) element);
return super.getText(element);
but it is not quite right, isn't it?
and i suggest to add this code to SimpleContentProposalProvider:
public String toString() {
return proposal;
Kurill
Re: SimpleContentProposalProvider with LabelProvider gives a wrong proposal text [message #333433 is a reply to message #333432] Thu, 11 December 2008 02:26 Go to previous messageGo to next message
> return proposal;
Please file an enhancement request at bugzilla.
http://bugs.eclipse.org/bugs/
Remy
Re: SimpleContentProposalProvider with LabelProvider gives a wrong proposal text [message #333434 is a reply to message #333433] Thu, 11 December 2008 05:00 Go to previous message
>> return proposal;
> Remy
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258412
Kurill
Previous Topic:Cannot run program "make": Unknown reason
Next Topic:Uninstall plugin
Current Time: Fri Jul 18 14:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.29032 seconds
