Home » Eclipse Projects » Eclipse Platform » Activate plugin after installation without restart
Activate plugin after installation without restart [message #333377] Mon, 08 December 2008 05:32 Go to next message
how can I activate a plugin after installation without a restart?
If I use
OperationsManager.getOperationFactory().createInstallOperati on(...) the
feature is installed, but I don't know how to activate it directly. My old
code was using org.eclipse.update.standalone.InstallCommand, and I could
be activated after installation with applyChangedNow().
So has anybody a idea how to a activate a installed
IInstallFeatureOperation. I tried IConfigFeatureOperation, but it doesn't
works.
Thanks for your help,
Markus
Re: Activate plugin after installation without restart [message #333378 is a reply to message #333377] Mon, 08 December 2008 05:51 Go to previous messageGo to next message
You can programmatically start/stop a bundle using.
Platform.getBundle("my.bundle.id").start();
Tom
Markus Schindler schrieb:
> Hello,
> If I use
> old code was using org.eclipse.update.standalone.InstallCommand, and I
> could be activated after installation with applyChangedNow().
> doesn't works.
> Markus
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Activate plugin after installation without restart [message #333379 is a reply to message #333378] Mon, 08 December 2008 08:13 Go to previous message
Thanks, for your reply.
But this doesn't work.
Platform.getBundle("my.plugin") is null, after installation. So non of the
perspectives or menues appear after installation.
-> After a restart all works fine
It looks like the features are only copied to the filesystem, and an entry
in an configuration is made, which tells eclipse after a restart to enable
these plugins.
Is there a way to enable them without an restart?
Btw. InstallCommand and applyChangesNow was doing this, but
IInstallFeatureOperation execute, and IConfigFeatureOperation execute are
not.
regards,
Markus
Previous Topic:How do you save your custom colours?
Next Topic:Catch every mouse click
Current Time: Sat Jul 19 03:26:03 EDT 2025
Powered by FUDForum. Page generated in 0.03476 seconds
