Doubleclick doesn't set a breakpoint [message #333373] |
Sat, 06 December 2008 06:31  |
currently Eclipse (I use version 3.2.2) doesn't set a breakpoint for
debugging when I doubleclick at the left border of the code editor within a
method. Some weeks ago it still worked. I have no idea, what may have
happened and changed, that on doubleclick Eclipse doesn't set the breakpoint
anymore. Fortunately I can still set the breakpoint by the context function
Toggle Breakpoint.
What may be the reason, that Eclipse doesn't set a breakpoint after a
doubleclick?
How to resolve the problem?
Thomas Wiedmann
Re: Doubleclick doesn't set a breakpoint [message #333382 is a reply to message #333373] |
Mon, 08 December 2008 08:48  |
On 12/6/2008 6:31 AM, Thomas Wiedmann wrote:
> Hello,
> within a method. Some weeks ago it still worked. I have no idea, what
> may have happened and changed, that on doubleclick Eclipse doesn't set
> the breakpoint anymore. Fortunately I can still set the breakpoint by
> the context function Toggle Breakpoint.
> doubleclick?
First I'd recommend upgrading to the latest version. You might be
running into this bug, which has been fixed:
https://bugs.eclipse.org/239317 (you'd see the NPE in your Error Log, if
that is the problem).
Hope this helps,
Eric
FUDForum. Page generated in 0.04130 seconds
