Home » Modeling » TMF (Xtext) » Quickfix NullPointerException in PartialSerializer
Quickfix NullPointerException in PartialSerializer [message #1779172] Wed, 03 January 2018 13:51 Go to next message
Sergio Otero is currently offline Sergio OteroFriend
Member
I'm having problems in Xtext 2.13 with quickfixes that i didn't have in 2.12, i suppose related to the changes applied to support multiple quickfix resolutions.
The problem appears when a node A is added to the AST tree and then another node is added as a child of A
	at org.eclipse.xtext.ide.serializer.impl.PartialSerializer$SerializeRecursiveStrategy.serialize(PartialSerializer.java:155)
	at org.eclipse.xtext.ide.serializer.impl.PartialSerializer.serializeChanges(PartialSerializer.java:280)
	at org.eclipse.xtext.ide.serializer.impl.RecordingXtextResourceUpdater.applyChange(RecordingXtextResourceUpdater.java:80)
	at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.endRecordChanges(ChangeSerializer.java:162)
	at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.applyModifications(ChangeSerializer.java:93)
	at org.eclipse.xtext.ui.editor.model.edit.BatchModification.applyInWorkspace(BatchModification.java:142)
The problem happens with a single quickfix, but it can be avoided somehow waiting to add the node A until it's fully set.
The problem is much more difficult to solve if several quickfixes are applied together and the business rules are complex
As an example, i've made a simple test case
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	classes+=Class* statements+=Statement+;
Class:
	'class' name=ID '{' vars+=Variable+ '}';
Variable: name=ID;
Statement: var=[Variable|VariableQN] '=' INT;
VariableQN hidden(): ID '.' ID;
	@Fix(Diagnostic.LINKING_DIAGNOSTIC)
	def void fixMissingEntity(Issue issue, IssueResolutionAcceptor acceptor) {
		if (issue.message.contains("Variable")) {
			fixMissingVariable(issue, acceptor);
	private def fixMissingVariable(Issue issue, IssueResolutionAcceptor acceptor) {
		acceptor.acceptMulti(
			issue,
			"Create missing variable definition",
			"Entity.gif",
			[ Statement element, ICompositeModificationContext<Statement> context |
				val fullReferenceName = getIssueMissingReferenceName(context.issue)
				val nameArray = fullReferenceName.split("\\.")
				val className = nameArray.get(0)
				val fieldName = nameArray.get(1)
				val root = element.eContainer as Model
				context.addModification(root, [ctx |
					var cl = root.classes.findFirst[it.name == className]
					if (cl === null) {
						// The class didn't exist
						cl =  MyDslFactory::eINSTANCE.createClass() => [
							name = className
						// before adding the class, we can add the field
						addVariable(cl, fieldName)
						ctx.classes.add(cl)
						// after adding the class, adding the field will cause NullPointerException in Serialization
						// addVariable(cl, fieldName)
					} else {
						// The class existed (maybe created in a previous multiquickfix)
						// NullPointerException if 2 fixs are applied together and the parent class was added in the first fix
	protected def boolean addVariable(Class cl, String fieldName) {
		val atr = MyDslFactory::eINSTANCE.createVariable() => [
			name = fieldName
		cl.vars.add(atr)
	private def String getIssueMissingReferenceName(Issue issue) {
		// Not the best way ...
		val issueMessage = issue.message
		val j = issueMessage.lastIndexOf("'")
		val i = issueMessage.lastIndexOf("'", j - 1)
		issueMessage.substring(i+1, j)
Example code:
// aplying the fix to this 2 problems together works because they create their own classes
Class1.test1 = 1
Class2.test2 = 1
// aplying the fix to this 2 problems together don't work because the first adds the class plus field and the second adds another field to the new class
Class3.test3 = 1
Class3.test4 = 1
Re: Quickfix NullPointerException in PartialSerializer [message #1779192 is a reply to message #1779172] Wed, 03 January 2018 17:19 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
did you opt in to used the new serializer? seems so since you use the multi quickfix.
can you please create a issue at github.com/eclipse/xtext-core
Twitter : @chrdietrich
Re: Quickfix NullPointerException in PartialSerializer [message #1779226 is a reply to message #1779192] Thu, 04 January 2018 08:06 Go to previous message
Member
https://github.com/eclipse/xtext-core/issues/597
I have a grammar used with legacy code and clients always send code with missing parts, so it's very useful to be able to apply massive quickfixes.
I kind of implemented a menu option to apply single quickfixes one after another project-wide (only aplied to a few specific custom quickfixes) and it worked pretty well in 2.12
After changing to 2.13, the output of the multiple single-quickfixes was corrupted, so i changed it to multiquickfixes and then i faced with the nullPointers
As a side question, if a quickfix has to modify a referenced resource (for example, add a field to a class in other source file), can it be done as if it were in the same source file or it needs additional steps?
Previous Topic:TypeReference for nested annotations class
Next Topic:How to parse a normal text file for unit test
Current Time: Sun Apr 28 23:22:45 GMT 2024
Powered by FUDForum. Page generated in 0.02616 seconds
