Home » Eclipse Projects » Eclipse Platform » howto provide context menu actions in a tree in a formeditor
howto provide context menu actions in a tree in a formeditor [message #333340] Thu, 04 December 2008 09:07 Go to next message
I've got a formeditor setup that has an swt Tree (using TreeViewer) embedded
in it. I'd like to provide a context menu with standard actions such
as "cut","copy","paste" for this. I tried to do this using something like:
MenuManager contextMenu = new MenuManager();
contextMenu.setRemoveAllWhenShown( true );
contextMenu
.add( new CopyMapEntriesAction( map, viewer ) );
Menu m = contextMenu.createContextMenu( viewer.getControl() );
viewer.getControl().setMenu( m );
editor.getSite().registerContextMenu( contextMenu, viewer );
However all I do get is a contex menu that contains stuff like "Run A..".
I've tried to look into how the PDE form editor does this, but couldn't see
anything I'm doing wrong.
Do I have to register the action somehow via plugin.xml? I didn't think this
would be necessary as I'm using a
setActionDefinitionId("org.eclipse.ui.edit.copy").
Anybody has a sample for a simple formeditor that provides the standard
copy/paste action on a tree view?
Andreas
Re: howto provide context menu actions in a tree in a formeditor [message #333341 is a reply to message #333340] Thu, 04 December 2008 09:05 Go to previous messageGo to next message
See some of the links in my sig which explains commands (hooking into
copy, ctrl+C involves providing handlers and using the
org.eclipse.ui.menus extension with a popup: locationURI) or
http://www.eclipse.org/articles/article.php?file=Article-act ion-contribution/index.html
for the older action based contributions.
PW
Paul Webster
Re: howto provide context menu actions in a tree in a formeditor [message #333362 is a reply to message #333341] Fri, 05 December 2008 10:22 Go to previous message
Thanks, unfortunately none of those really helped. Its basic API
information, but simply not small example. Either I'm too stupid or too
ignorant to put the information from those pages together into
code+plugin.xml.
Anyway, I found a bit simpler sample code in the breakpointsview in
org.eclipse.debug.ui and that does seem to work as I want it to.
Andreas
Previous Topic:Finding the list of classes in a package like Package Explorer
Next Topic:How to refresh or force to redraw view part
Current Time: Wed Sep 10 18:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.06406 seconds
