Platform Command Framework suggestions [message #333279] |
Wed, 03 December 2008 04:14  |
Recently i have been converting our app over to use handlers etc and came
across a few niggles and wonder if a couple of suggestions would be
appreciated?
When defining a handler within the plugin.xml, it becomes very difficult
to distinguish between them as the text simply states '(handler)' for each
of them under the extensions. Perhaps an improvement would be to add a
name/label field or even display the command id as the text?
Finally, when defining a property tester each property is listed on a
single 'properties' line separated by a comma. It may easier to view if
individual properties were added as new elements. (eg Right click -> Add
property)
FUDForum. Page generated in 0.04972 seconds
