Home » Eclipse Projects » Eclipse Platform » No Syntax coloring when opening a file with custom editor
No Syntax coloring when opening a file with custom editor [message #333270] Tue, 02 December 2008 16:14 Go to next message
I have been updating a custom editor (cmakeed.sourceforge.net) and all
is generally going well except I have a small stumbling block.
My editor opens files with a name of "CMakeLists.txt" and "*.cmake". I
have a few projects where I have template files with names like
CMakeLists.txt.in and Project.cmake.in.
I can right click on the file in the project explorer and select the
"Open With..." menu which brings up the list of available editors. I
select CMakeEd and an editor opens BUT I have no syntax coloring or any
other custom feature that I wrote. The issues seems to be when I hit
the "createEmptyDocument(IFile) method in the
ResourceTextFileBufferManager class.
The line:
final IDocumentSetupParticipant[] participants=
((ResourceExtensionRegistry)fRegistry).getDocumentSetupParti cipants(file);
will
return a zero length array. I am assuming because it looks at the
extension points for my custom reader (among others) and decides that
the file name does not match what is in my extension point and so
returns nothing.
So my question: How do other editors handle this? I know I have had
instances where I have opened a file like source.cpp.in as a C plus
plus file and gotten the correct coloring, highlighting and all that.
Thanks for any help
Mike Jackson
BlueQuartz Software
Re: No Syntax coloring when opening a file with custom editor [message #333283 is a reply to message #333270] Wed, 03 December 2008 07:08 Go to previous messageGo to next message
> any other custom feature that I wrote. The issues seems to be when I
> hit the "createEmptyDocument(IFile) method in the
> The line:
> will
> returns nothing.
Do something like that:
IDocumentProvider provider= new TextFileDocumentProvider();
provider= new ForwardingDocumentProvider(yourPartitioning, new
YourDocumentSetupParticipant(), provider);
setParentDocumentProvider(provider);
Dani
> Thanks for any help
> Mike Jackson
> BlueQuartz Software
Re: No Syntax coloring when opening a file with custom editor [message #333293 is a reply to message #333283] Wed, 03 December 2008 09:50 Go to previous messageGo to next message
On 2008-12-03 07:08:58 -0500, Daniel Megert <daniel_megert@ch.ibm.com> said:
>> The line:
will
return
>> a zero length array. I am assuming because it looks at the extension
>> points for my custom reader (among others) and decides that the file
>> name does not match what is in my extension point and so returns
>> nothing.
> Dani
>> Thanks for any help
>> Mike Jackson
>> BlueQuartz Software
Awesome.. Thanks.. But I am still a bit "wet behind the ears" with this
so just _where_ would I put this code?
Mike Jackson
Re: No Syntax coloring when opening a file with custom editor [message #333302 is a reply to message #333293] Wed, 03 December 2008 12:26 Go to previous messageGo to next message
> said:
>>> all is generally going well except I have a small stumbling block.
>>> I have a few projects where I have template files with names like
>>> The line:
> will
> return
>>> nothing.
>> new YourDocumentSetupParticipant(), provider);
>> Dani
>>> Thanks for any help
>>> Mike Jackson
>>> BlueQuartz Software
> this so just _where_ would I put this code?
This needs to be in the constructor of your own document provider.
Dani
> Thanks
> Mike Jackson
Re: No Syntax coloring when opening a file with custom editor [message #333305 is a reply to message #333302] Wed, 03 December 2008 14:27 Go to previous messageGo to next message
On 2008-12-03 12:26:14 -0500, Daniel Megert <daniel_megert@ch.ibm.com> said:
>>>> The line:
will
return
a
>>>> nothing.
>>> Dani
>>>> Thanks for any help
>>>> Mike Jackson
>>>> BlueQuartz Software
> Dani
Ok. I put that in the Constructor of my "CMakeDocumentProvider" class.
I also had to change the CMakeEditor class to extend from
AbstractDecoratedTextEditor. Things still seem to work with regard to
all the other behaviors. I still have the same problem at the same line
as my original posting.
will
return a zero length array so the participant.setup(document); line
will never get called.
I am sure I am just missing something hopefully obvious.
Thanks for the help
Mike Jackson
Re: No Syntax coloring when opening a file with custom editor [message #333306 is a reply to message #333302] Wed, 03 December 2008 14:49 Go to previous message
>>>> The line:
will
return
a
>>>> nothing.
>>> Dani
>>>> Thanks for any help
>>>> Mike Jackson
>>>> BlueQuartz Software
> Dani
Got it!!. In the constructor for CMakeEditor I put the following:
provider= new
ForwardingDocumentProvider(UIPlugin.CMAKE_PARTITIONING, new
CMakeDocumentSetupParticipant(), provider);
setDocumentProvider(provider);
And now things work as hoped/expected. THANKS!!.
Mike
Previous Topic:Custom Editor Saving File causes cursor position to be reset
Next Topic:CNF
Current Time: Wed Jul 16 04:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.08290 seconds
