Home » Eclipse Projects » Eclipse Platform » Moving resources between projects
Moving resources between projects [message #333263] Tue, 02 December 2008 11:42 Go to next message
When moving a resource (file) between two folders of the same project,
my builder gets two events: one with delta.getKind() ==
IResourceDelta.ADDED with a non-null delta.getMovedFromPath(), and one
with delta.getKind() == IResourceDelta.REMOVED with a non-null
delta.getMovedToPath(), which allow me to identify the actual "move" event.
However, when moving a resource from one project to another (both of
them having the builder enabled) I still get the ADDED and REMOVED
events but getMovedToPath() and getMovedFromPath() both return null -
and therefore I cannot identify the move event.
Any thoughts on this?
Dimitrios
Re: Moving resources between projects [message #333281 is a reply to message #333263] Wed, 03 December 2008 05:50 Go to previous messageGo to next message
Hi, what Eclipse version do you use? I checked your case on Build id:
N20081127-2000 and it works fine.
Re: Moving resources between projects [message #333284 is a reply to message #333281] Wed, 03 December 2008 07:14 Go to previous messageGo to next message
I'm using 3.4.0 I20080617-2000
Re: Moving resources between projects [message #336043 is a reply to message #333284] Thu, 14 May 2009 18:15 Go to previous messageGo to next message
I'm seeing the same behavior as Szymon. If I have just a simple
ResourceChangeListener the delta movedFromPath is set, but not when
looking at the delta in our builder.
Re: Moving resources between projects [message #336120 is a reply to message #336043] Fri, 22 May 2009 10:25 Go to previous message
Anyone have any thoughts on this? It seems like a bug that the resource
change listener's resource deltas would have the movedFromPath set, but
not the builder's.
Richard
Previous Topic:path in editor menus
Next Topic:PluginModelManager.initializeTable() problem in self-hosted application
Current Time: Thu Jul 17 03:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.48240 seconds
