Home » Eclipse Projects » Eclipse Platform » Basic case of DLL import failing
Basic case of DLL import failing [message #333187] Fri, 28 November 2008 08:56 Go to next message
Originally posted by: torbjorn.ghostwriter.no
I've done what I thought were the necessary steps to access a DLL in a
plugin:
1. I put the dll file (jdic_misc.dll) in the plugin root
2. I put the following code in the plugin:
System.loadLibrary("jdic_misc.dll");
However, the line throws the following exception:
java.lang.UnsatisfiedLinkError: no jdic_misc.dll in java.library.path
.... which I interpret as not being able to find the DLL at all, rather than
an issue with further linking.
Have I missed some steps? I read that the Bundle-NativeInclude (or whatever
it was called) is unnecessary in 3.4, and I tried including the DLL in the
build, but nothing helps. Note that I'm running this from Eclipse directly
(i.e. not exported or anything like that)
Re: Basic case of DLL import failing [message #333190 is a reply to message #333187] Fri, 28 November 2008 10:25 Go to previous message
Here's one example.
http://litrik.blogspot.com/2007/08/secrets-of-bundle-nativec ode.html
Could you provide a link to where you were reading that
Bundle-NativeCode is not necessary? I don't believe that's the case (in
OSGi and bundles, you do need it).
SWT doesn't require java.library.path any more, even when run as an SWT
java app, but that's because they have extra code that extracts their
native libraries to a temporary location if they are not already available.
PW
Paul Webster
Previous Topic:completion does not work, why?
Next Topic:Learning Eclipse: If you knew then what you knew now....
Current Time: Fri Jul 18 12:55:50 EDT 2025
Powered by FUDForum. Page generated in 0.02672 seconds
