Home » Eclipse Projects » Eclipse Platform » Show/hide view declararively
Show/hide view declararively [message #333117] Wed, 26 November 2008 03:02 Go to next message
Hy.
Is there a way to declare the visibility of a view declaratively?
Background: My RCP app uses a database for storing the whole data. If
the app is not connected to the database, then instead of the normal
views a hint should be presented to the user, that he should connect to
the database first.
As there is no glasspane in SWT (which would be the best option for this
task), I added another view with a "Please connect to database" message
on it and shift between this view and the normal views dependent on the
database connection. (Any better ideas for such a case?)
At the moment I do this fully programmatically, but I wonder if there is
a way to do this declaratively. Perhaps with the use of conditional
property testers, like the declaration for enabling/disabling handlers.
Kai
Re: Show/hide view declararively [message #333129 is a reply to message #333117] Wed, 26 November 2008 07:25 Go to previous messageGo to next message
> the database first.
What about the *same* view, but with different top composite, depending
on the situation? The "error-case" composite could have a totally
different look-and-feel (including a message or some such).
Alternatively, you could do the same thing via your own extension point.
This extension point could also reuse the core-expression's (There
exists a programmer API for that), so you could define (run-time)
conditions under which the corresponding composite is instantiated.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Show/hide view declararively [message #333150 is a reply to message #333129] Wed, 26 November 2008 17:31 Go to previous message
Hello Daniel.
Thanks for the help.
I think I will go with your first alternative, even if it is not so nice
as there are minimum three views per perspective, and every view will
then have an error-case composite.
I also thought about implementing your second alternative with views.
Like a "view visible when" extension point. But this is also a bit
cumbersome.
I really hope there will be one day something like a glasspane for SWT.
Greetings from Mainz to Bremen :-)
Kai
>> to the database first.
>> this task), I added another view with a "Please connect to database"
>> message on it and shift between this view and the normal views
>> dependent on the database connection. (Any better ideas for such a case?)
> Daniel Krügler
Previous Topic:Where to put log4j.properties
Next Topic:Disable tabs in JSP editor?
Current Time: Sat Aug 23 02:41:26 EDT 2025
Powered by FUDForum. Page generated in 0.03982 seconds
