Home » Eclipse Projects » Eclipse Platform » Learning Eclipse: If you knew then what you knew now....
Learning Eclipse: If you knew then what you knew now.... [message #333102] Tue, 25 November 2008 16:47 Go to next message
Originally posted by: marc.esher.comcast.net
I've been thinking about the question: "if you were getting started with
Eclipse plugin programming, how would you start? What are the top 5
must-have resources, the best "timesaving tips and tricks for finding what
you need to know", etc. In other words, if knowing now what you knew 5 years
ago you could go back in time, grab yourself by the shirt collar, and say
"hey, dummy, here's what you need to know"... what would those things be?
What keeps you productive and rockin?
I'm asking this for myself somewhat in the context of eclipse
programming, but also because as a former teacher and current mentor (albeit
not in eclipse programming) I'm curious about the topic and always
interested in "secrets of the masters" type stuff.
This came up during a conversation along the lines of "Pick any language out
there that you know nothing about. Imagine you have to learn it. How would
you proceed?" And while Eclipse isnt' a language, it's certainly a sizeable
ecosystem.
thanks!
Re: Learning Eclipse: If you knew then what you knew now.... [message #333106 is a reply to message #333102] Tue, 25 November 2008 19:14 Go to previous messageGo to next message
Originally posted by: loosersinc.gmx.de
Marc E schrieb:
> What are the top 5 must-have resources, the best "timesaving tips and tricks for finding
> what you need to know",
These are my top 5 (from RCP Developers view)
1. Read carefully. Take your time to understand !
2. Find a good tutorial (e.g. www.vogella.de)
3. Look @sources
4. www.eclipse.org/articles
5. news.eclipse.org
Last but not least:
avoid books with complex example Apps
CU
Re: Learning Eclipse: If you knew then what you knew now.... [message #333108 is a reply to message #333106] Tue, 25 November 2008 19:21 Go to previous messageGo to next message
forgot something:
care 4 your bookmarks. Mark good articles and keep it synchronized and
in comprehensible subfolders.
Use e.g Foxmarks to keep them anywhere you're connected...
Re: Learning Eclipse: If you knew then what you knew now.... [message #333197 is a reply to message #333108] Sat, 29 November 2008 23:00 Go to previous message
Thanks for the tips, Frank!
"Frank Schaare" <loosersinc@gmx.de> wrote in message
news:ggi4qf$f5f$1@build.eclipse.org...
> forgot something:
> care 4 your bookmarks. Mark good articles and keep it synchronized and in
Previous Topic:Basic case of DLL import failing
Next Topic:How to exclude a string in a regex search?
Current Time: Wed Jul 09 23:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.03043 seconds
