Home » Eclipse Projects » Eclipse Platform » Syntax Highlighting Rules for Custom Editor
Syntax Highlighting Rules for Custom Editor [message #333101] Tue, 25 November 2008 16:37 Go to next message
I am working on the CMake Editor Plugin and I am coming across an
interesting issue where I am trying to parse through the document
looking for user defined variables. This looks like the following:
set (myVar "Foo")
That part I can do ok. The issue I am having is when the user starts
typing that line like so:
set (myV
My IRule, IPredicateRule based class will parse the 'myV' and add that
to its list of variables. I tried various approaches to "fix" this
issue like disabling the class after the initial document is read or
only enabling it during saves (so the user has to save the document to
see the new variable show up) but ultimately nothing is really working.
I thought about trying to get the position of the cursor and if that
position is at the end of the current text part then skip the addition
of the word to the list of variables. The problem with that approach
(among many I guess) is that I can not figure out how to get the
current cursor position from an IDocument which is all I seem to have
access to. I do see issues with that approach any ways.
What are some of the approaches that have been used by other editor
writers? I tried to work through the CDT source code or the JDT editor
source code but it is pretty intimidating to attempt to search through.
Thanks for any help or advice.
Mike Jackson
BlueQuartz Software.
www.bluequartz.net
Re: Syntax Highlighting Rules for Custom Editor [message #333125 is a reply to message #333101] Wed, 26 November 2008 06:42 Go to previous message
> set (myVar "Foo")
> set (myV
Use
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getPre sentationReconciler(ISourceViewer)
as a starting point into the JDT code.
Dani
> Mike Jackson
> www.bluequartz.net
Previous Topic:Launching external executable?
Next Topic:how to terminate new process created via Runtime.exec()
Current Time: Thu Jul 17 19:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.03638 seconds
