Re: How to create a Device to use in the 4DIAC IDE [message #1776614 is a reply to message #1776547] |
Sat, 18 November 2017 13:17 |
hi,
currently to use 4diac for programming a certain device you need to port the 4diac run-time environment (FORTE) to the device. This typically requires a certain openness of the device (nearly all modern PLCs, e.g., Wago, Beckhoff, the new Phoenix Contact, Bosch Rexroth) or support from the device vendor. 4diac already supports quite a number of devices and the list is growing with each release. Currently we are working on 4 new devices. If you have a certain device in mind we are happy to support you in investgating the option and also porting FORTE.
My experience with older PLCs is that they have very dedicated hardware which makes it hard to change anything for them. Here maybe an option could be to develop code generators which would generate legacy PLC code out of 4diac applications. 4diac-ide's plugin concpet would allow this, but it would be quite some work.
Re: How to create a Device to use in the 4DIAC IDE [message #1776617 is a reply to message #1776614] |
Sat, 18 November 2017 15:20 |
Steven Snow Messages: 3 Registered: November 2017 |
Junior Member |
Hello, and thank you for the quick response.
As for specific hardware, a good one in my opinion and also for some of my current solutions I provide would be Rockwell Automation Micro800 series and their associated HMI's the PanelView 800 line. They are purported to be open PLC's, I am sure with a Rockwell twist.
Some of the reasoning behind my question was to eventually eliminate my windows OS based PC's needs in my chosen line of work, which I will very likely retire from before I accomplish that.
Is there a template available for making a device in (I assume FORTE) where I could attempt to build the ones I need as I need them? Is it the same as making an Eclipse Plugin? I have access to hardware usually fairly readily, and in most instances can get a good amount of technical information from the OEM. I would of course freely release it back to the community, in case someone else ran into the same need.
A number of years back, I was working as a contractor at a large automation system integrator, they had developed a C program that would write pallet traffic PLC code for the Siemens S5 PLC, as Function Blocks of statement list.
[Updated on: Sat, 18 November 2017 15:38] Report message to a moderator
Re: How to create a Device to use in the 4DIAC IDE [message #1776618 is a reply to message #1776617] |
Sat, 18 November 2017 15:40 |
Hi, you are welcome.
the Miro800 seems a good fit for 4diac. What you need to do is to compile FORTE and bring run FORTE directly on the MICRO800. FORTE is written in C++. Therefore you need a C++ compiler for your target device. Depending on the device you need to do operating or device specific adjustments of FORTE. AFAIK Rockwell has typically vxWorks which is already supported by FORTE. I would say for starting it would make sense to get familiar with how to build and run forte for example on a Windows or Linux PC. you can find this in the docs.
FUDForum. Page generated in 0.05159 seconds
