Home » Eclipse Projects » Eclipse Platform » Eclipse on Windows vista cannot use update manager
Eclipse on Windows vista cannot use update manager [message #333083] Tue, 25 November 2008 04:18 Go to next message
Hi ,
I am a big fan of eclipse and I use it for work and home regularly.
I recently got a new sony vaio with windows vista on it and then started
the trouble.
The issue is that whenever I try to use the update manager to install or
update remote plugins, I get an error stating this
"Network connection problems encountered.Premature end of file" .
I run eclipse as an administrator and my filepath isnt too long(This is
known to mess up softwares on vista).
Eclipse is not present inside c:/program_files .
Wonder what I have to do.Its been weeks since I encountered this issue and
this is a big showstopper for me!
Please advice!
Re: Eclipse on Windows vista cannot use update manager [message #333084 is a reply to message #333083] Tue, 25 November 2008 05:05 Go to previous messageGo to next message
vencool@gmail.com (Venkat ) writes:
> or update remote plugins, I get an error stating this
> is known to mess up softwares on vista).
> and this is a big showstopper for me!
Eclipse update works for me on Windows Vista. Since we have not seen a
lot of complaints about update on Vista I suspect it works for a lot
of people. It seems likely that there is something unusual about your
configuration.
What have you done so far to try to discover what is unusual about
your configuration?
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Eclipse on Windows vista cannot use update manager [message #333086 is a reply to message #333084] Tue, 25 November 2008 05:20 Go to previous messageGo to next message
Well, I dont think that my platform is unusual in any sense.One thing I
have noticed is that even softwares other than eclipse like tortoiseSvn
that try to connect to remote sites fail with the same kind of errors.
Is there anything like elevated mode or something in which I have to run
eclipse?
Venkat
Re: Eclipse on Windows vista cannot use update manager [message #333087 is a reply to message #333086] Tue, 25 November 2008 05:49 Go to previous messageGo to next message
> I have noticed is that even softwares other than eclipse like
> tortoiseSvn that try to connect to remote sites fail with the same
> kind of errors.
This suggests that the problem is with your network configuration in
general rather than anything specifically to do with Eclipse.
If other things are failing in the same way then you need to look at
what they have in common, especially in network configuration. If you
have any software that can access the update sites then you need to
look at what it does differently from the things that fail.
Re: Eclipse on Windows vista cannot use update manager [message #333097 is a reply to message #333086] Tue, 25 November 2008 15:29 Go to previous messageGo to next message
> eclipse?
Check your Windows Firewall settings.
Re: Eclipse on Windows vista cannot use update manager [message #333155 is a reply to message #333097] Thu, 27 November 2008 00:31 Go to previous message
Fixed this!!
It was happening because windows live onecare that comes installed with
windows vista was blocking all sorts of internet connections and ports .
Thanks for your time and comments
Previous Topic:Disable tabs in JSP editor?
Next Topic:Build Platform Runtime Binary from Source
Current Time: Mon Sep 01 01:40:07 EDT 2025
Powered by FUDForum. Page generated in 0.18475 seconds
