Missing requirement Apache Batik CSS with Eclipse Oxygen [message #1776245] |
Tue, 14 November 2017 11:59 |
since Kepler I looked into Eclipse E4 development. Updating to Oxygen now I can't export my product. Within Eclipse itself everything is fine. It doesn't matter, if I'm using:
- three project: product, plugin and feature
- two projects: product and plugin
- or just one combining product and plugin
Whatever I do, as soon as I try to use the "Eclipse Product export wizard" the wizards fails on the Apache Batik CSS:
"Missing requirement: Eclipse CSS Core Support 0.12.101.v20170712-1547 (org.eclipse.e4.ui.css.core 0.12.101.v20170712-1547) requires 'bundle org.apache.batik.css 1.7.0' but it could not be found"
Actually I can imagine four theoretical solutions:
1 - Force the wizard to do the same as Eclipse itself and simply export the product as I request
2 - Upgrade org.eclipse.e4.ui.css.core to use Apache Batik CSS 1.8.0
3 - Downgrade org.eclipse.e4.ui.css.core to use Apache Batik CSS 1.6.0
4 - Install Apache Batik CSS 1.7.0
I already tried installing Apache Batik CSS 1.7.0 using the Oxygen Orbit update site, but the org.apache.batik.css within my product ("Content" tab "Plug-ins and Fragments") still references version 1.8.0.v20170214-1941 and I can't change it.
Searching the web for help I found many old post but no solution I could apply.
What do I need to do/change to get my E4 running outside Eclipse as well?
Many thanks in advance
Re: Missing requirement Apache Batik CSS with Eclipse Oxygen [message #1784947 is a reply to message #1784946] |
Fri, 06 April 2018 08:53 |
I'm on Oxegen as well now. I reinstalled, updated and retried everything until it finally worked. Moving forward and backwards through my backups, I still neither know how I finally managed and least of all, how it is supposed to work straight away. Any step-by-step tutorial with proven working result and named libraries with precisely defined version numbers is highly appreciated.
FUDForum. Page generated in 0.07838 seconds
