Home » Eclipse Projects » Eclipse Platform » extension points in fragment
extension points in fragment [message #333044] Fri, 21 November 2008 11:21 Go to next message
I have defined some extension points in a fragment.
But I don't see those extension points in another plugins (those plugins
do have dependency on host plugin of that fragment)
Just wondering if it is the case that extension point must be defined in
plugin but not in a fragment?
Or am missing something?
Using eclipse 3.4
Thanks.
- PC
Re: extension points in fragment [message #333056 is a reply to message #333044] Fri, 21 November 2008 17:23 Go to previous messageGo to next message
PC wrote:
I don't think you can define extension points in a fragment. Fragments
are more for modifying the way a given plugin behaves internally (for
instance, for JVM or OS-dependent behavior). The interface that a
plug-in exposes to other plug-ins shouldn't depend on platform.
Why does your fragment need to be a fragment? Could it be a
full-fledged plug-in of its own?
Re: extension points in fragment [message #333093 is a reply to message #333056] Tue, 25 November 2008 11:43 Go to previous messageGo to next message
Thanks Walter , converted to plugin :-)
Walter Harley wrote:
> PC wrote:
>> plugins do have dependency on host plugin of that fragment)
>> in plugin but not in a fragment?
Re: extension points in fragment [message #1770102 is a reply to message #333093] Tue, 08 August 2017 06:55 Go to previous message
Not entirely true, but the file is not called plugin.xml, but fragment.xml:
https://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.pde.doc.user%2Fguide%2Ftools%2Fproject_wizards%2Fnew_fragment_project.htm
[Updated on: Tue, 08 August 2017 06:57] by Moderator
Previous Topic:get IFile from IDocument
Next Topic:GTK & Light Themes
Current Time: Fri Jul 18 17:12:58 EDT 2025
Powered by FUDForum. Page generated in 1.03545 seconds
