Home » Eclipse Projects » Eclipse Platform » Problem of update site with the protocol https
Problem of update site with the protocol https [message #332990] Tue, 18 November 2008 09:50 Go to next message
I'm encountering a certification error when trying to connect to an
Update
site using the https protocol through the Update Manager of Eclipse. The
problem may be that the SSL certificate of the site is invalid. Does
anyone know how to ignore it?
Thanks for your help.
Mabu
Re: Problem of update site with the protocol https [message #333018 is a reply to message #332990] Wed, 19 November 2008 10:50 Go to previous messageGo to next message
I've found the solution.
Re: Problem of update site with the protocol https [message #333019 is a reply to message #333018] Wed, 19 November 2008 10:56 Go to previous messageGo to next message
It would be nice, if you would share your solution with the
community!
Greetings from Bremen,
Daniel Krügler
Re: Problem of update site with the protocol https [message #333045 is a reply to message #333019] Fri, 21 November 2008 11:34 Go to previous message
It needs to add the SSL certificate to the JVM Certificate Keystore.
This site explains how to do it:
http://eclipse.open.collab.net/servlets/ProjectProcess?pageI D=3450
See the section:
« When I try to add my site to the task repositories, I get a Java error
that says SSL Handshake failed. What do I do? »
Best regards.
Mabu
Previous Topic:CVS and Eclipse metafiles
Next Topic:Controlling the position of items in the Coolbar
Current Time: Sat Aug 23 02:51:27 EDT 2025
Powered by FUDForum. Page generated in 0.03587 seconds
