Home » Eclipse Projects » Eclipse Platform » getConfiguredSites() method retuning an empty array
getConfiguredSites() method retuning an empty array [message #332939] Fri, 14 November 2008 13:23
I'm working on a product based on Eclipse 3.4.1 + patches (P2 enabled).
When I invoke the following method in this product, it is retuning an empty
array even though my platform.xml has 2 sites (including the default site)
clearly defined and enabled.
org.eclipse.update.core.SiteManager.getLocalSite().getCurren tConfiguration().getConfiguredSites();
Note that I checked the Eclipse Installer/Updater dialog (P2) and verified
that all the features in the 2 sites were properly installed in deed.
Is it possible for getConfiguredSites() method to return an empty array when
sites are properly defined and enabled in platform.xml?
Thanks in advance!
Sudarsha
Previous Topic:Any way to lock a Cell during table update??
Next Topic:[Commands Framework] differentiating between view popup and toolbar
Current Time: Fri Jul 18 07:15:06 EDT 2025
Powered by FUDForum. Page generated in 0.03590 seconds
