Home » Eclipse Projects » Eclipse Platform » disable "Show All Wizards" check box when using activities
disable "Show All Wizards" check box when using activities [message #332938] Fri, 14 November 2008 12:07 Go to next message
Is there a way in Eclipse 3.4.1 to remove the "Show All Wizards" check
box when hiding new wizards with activities? I have some plugin
contributions that I don't want the user to make them appear in my
application.
Mircea
Re: disable "Show All Wizards" check box when using activities [message #333051 is a reply to message #332938] Fri, 21 November 2008 14:58 Go to previous messageGo to next message
Mircea Luchian wrote:
> Hello,
> application.
Normal activities will always show that checkbox (as they're designed to
unclutter the interface until the user wants more). In 3.4 there are
expression based activities that will remove the wizard completely and
don't add the "Show All Wizards" checkbox.
PW
Paul Webster
Re: disable "Show All Wizards" check box when using activities [message #333062 is a reply to message #333051] Mon, 24 November 2008 03:47 Go to previous messageGo to next message
>> Hello,
>> application.
I'm impressed, although I wonder concerning the nomenclature of
"expression-based activities". AFAIK "classic" expressions already
allow (regular) expressions to restrict them. If I read your
intention correctly, it seems that the core command expressions
can be used to control activities - is that right? And they are
available as of Eclipse 3.4?
It would be very nice, if you could give us a pointer to an
example which shows these extended use-cases of activities
combined with core expressions.
Thanks in advance,
Daniel Krügler
Re: disable "Show All Wizards" check box when using activities [message #333071 is a reply to message #333062] Mon, 24 November 2008 08:44 Go to previous messageGo to next message
Yes, available in 3.4. The examples that we have is a small entry in
the help at
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench_advext_activities.htm
plus an implementation in org.eclipse.ui.examples.contributions in CVS.
They were added under bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201052
Later,
PW
Paul Webster
Re: disable "Show All Wizards" check box when using activities [message #333073 is a reply to message #333071] Mon, 24 November 2008 10:01 Go to previous messageGo to next message
> the help at
Thanks Paul, for this IMO quite important and powerful
extension of activities! We considered using activities in
our original RCP design but withdraw them because of just
this (for us) unwanted effect, that any user can auto-promote
to a some kind of "super-user" and thus can circumvent
a programmer-intended barrier - just the issue the OP
mentioned!
I wonder why this new feature had not been emphasized more
strongly in the release readme? - it really would have been
worth it!
- Daniel Krügler
Re: disable "Show All Wizards" check box when using activities [message #333079 is a reply to message #333071] Mon, 24 November 2008 15:13 Go to previous messageGo to next message
Thank you Paul,
I will check the help file and share my findings.
Mircea
> the help at
> Later,
> PW
Re: disable "Show All Wizards" check box when using activities [message #333096 is a reply to message #333073] Tue, 25 November 2008 15:22 Go to previous message
> worth it!
It's an added enhancement, but activities are about UI simplification
and progressive disclosure to advanced users and are not really more
than a cosmetic security feature :-)
The expression based activities 1) remove items more completely (which
is why you can't get them back with a show all) and 2) don't allow the
user to modify them (their state is entirely based on the expression,
not anything else).
There is some good work at the equinox level to do with security, but I
haven't seen a good story for propagating it up to the UI
PW
Paul Webster
Previous Topic:Problems sending simple emails
Next Topic:Disabling A Context Menu Item Depending On Where You Are In A Tree
Current Time: Sat Jul 26 10:05:25 EDT 2025
Powered by FUDForum. Page generated in 0.23421 seconds
