Home » Eclipse Projects » Eclipse Platform » [JFace] Text and Dialog button CellEditor?
| [JFace] Text and Dialog button CellEditor? [message #332934] |
Fri, 14 November 2008 11:25  |
There is DialogCellEditor and TextCellEditor, but what I need is a
combination of the two, a CellEditor that allows the user to type in
text and also has the ... button for opening a Dialog to select a value.
I've trying to write one by extending DialogCellEditor and adding a Text
field (lots of code copied from TextCellEditor) but I'm having annoying
difficulties getting focus handling to work properly (this is only the
latest issue in a painful progression of them).
Has anyone seen such a CellEditor that I could use rather than continue
to flounder writing my own?
Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #332972 is a reply to message #332944] |
Mon, 17 November 2008 10:55   |
On 11/15/2008 8:31 AM, Tom Schindl wrote:
> Do you have code for me to play with?
This extends another of our home-grown classes,
SelectionDialogCellEditor. You can either change it to extend
org.eclipse.emf.common.ui.celleditor.ExtendedDialogCellEdito r or get
SelectionDialogCellEditor from
< https://www.skywayperspectives.org/fisheye/browse/CVS_OpenSo urce/skyway/common/plugins/org.skyway.ui/src/org/skyway/ui/t ables>
Thanks for the help,
Eric
import java.text.MessageFormat;
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.FocusAdapter;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.FocusListener;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Text;
public abstract class TextAndDialogCellEditor extends
SelectionDialogCellEditor {
private Text textField;
private Button button;
private FocusListener textFocusListener;
public TextAndDialogCellEditor(ColumnViewer parent, ILabelProvider
labelProvider) {
super(parent, labelProvider);
protected Control createContents(Composite cell) {
textField = new Text(cell, SWT.NONE);
textField.setFont(cell.getFont());
textField.setBackground(cell.getBackground());
textField.addFocusListener(getTextFocusListener());
textField.addKeyListener(new KeyAdapter() {
public void keyPressed(KeyEvent event) {
keyReleaseOccured(event);
// Prevent Enter and Esc key traversal from esacping the Text and
being bubbled up to
// parent Controls (for example, to prevent a containing dialog from
getting the Enter or
// Esc key event that occur in this Text)
textField.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
if (e.detail == SWT.TRAVERSE_ESCAPE || e.detail ==
SWT.TRAVERSE_RETURN) {
e.doit = false;
return textField;
protected Button createButton(Composite parent) {
this.button = super.createButton(parent);
button.addFocusListener(new FocusAdapter() {
public void focusGained(FocusEvent e) {
System.out.println("Button gained focus");
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
System.out.println("Button selected");
return button;
protected FocusListener getTextFocusListener() {
if (textFocusListener == null) {
textFocusListener = new FocusAdapter() {
public void focusLost(FocusEvent event) {
System.out.println("Text lost focus");
setValue();
TextAndDialogCellEditor.this.focusLost();
return textFocusListener;
protected void keyReleaseOccured(KeyEvent keyEvent) {
if (keyEvent.keyCode == SWT.CR) { // Return key
setValue();
super.keyReleaseOccured(keyEvent);
protected void setValue() {
String newValue = textField.getText();
boolean newValidState = isCorrect(newValue);
if (newValidState) {
markDirty();
doSetValue(newValue);
} else {
// try to insert the current value into the error message.
setErrorMessage(MessageFormat.format(getErrorMessage(), new
Object[] { newValue.toString() }));
protected void updateContents(Object object) {
if (textField != null && labelProvider != null) {
textField.setText(labelProvider.getText(object));
protected void doSetFocus() {
// Overridden to set focus to the Text widget instead of the Button.
textField.setFocus();
textField.selectAll();
>> I guess I'll (try to) describe the issue I'm facing in case someone has
>> an idea for getting past it.
>> The problem with combining a Text and a Button in the same CellEditor
>> seems to be related to how to handle focus-lost events. The Text needs
>> to have a focus-lost handler that calls CellEditor.focusLost() so that
>> the value from the Text is pushed to the model [focusLost() calls
>> fireApplyEditorValue()] - when someone activates the editor, types into
>> the Text and then clicks elsewhere, the value they typed is pushed to
>> the model.
>> However, this interferes when the CellEditor open-dialog button is
>> pushed, because that triggers focus-lost to the Text which in turn
>> triggers fireApplyEditorValue() - the problem is that this indirectly
>> causes the ColumnViewerEditor to remove its listener from the cell
>> editor [see code buried deep in ColumnViewerEditor.applyEditorValue()].
>> So when the dialog is closed with a new value chose, the
>> ColumnViewerEditor is no longer listening to that CellEditor and doesn't
>> get the update.
>> Any ideas how to get around this conundrum?
>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #333229 is a reply to message #332972] |
Mon, 01 December 2008 10:32   |
Bump. Did anyone have a chance to look at this code or offer an
alternative implementation idea?
Eric
> Eric
> labelProvider) {
> @Override
> @Override
> // Prevent Enter and Esc key traversal from esacping the Text and being
> bubbled up to
> if (e.detail == SWT.TRAVERSE_ESCAPE || e.detail == SWT.TRAVERSE_RETURN) {
> e.doit = false;
> return textField;
> @Override
> @Override
> @Override
> return button;
> @Override
> setValue();
> @Override
> setValue();
> markDirty();
> } else {
> setErrorMessage(MessageFormat.format(getErrorMessage(), new Object[] {
> @Override
> @Override
>>>> value.
>>>> Text
>>> the model.
>>> get the update.
>>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #333827 is a reply to message #333229] |
Wed, 07 January 2009 12:41   |
Answering another question reminds me that I haven't answered your
question for quite some time.
Eric could you please create a fully running snippet. I can download the
missing class from your repo (though it looks like it's released under
GPL :-( but the binding domain-code would help me to get started maybe
you could provide a snippet without the need for this super-class
because the we could make up a snippet from it.
Tom
> Eric
>> Eric
>> labelProvider) {
>> @Override
>> @Override
>> bubbled up to
>> e.doit = false;
>> return textField;
>> @Override
>> @Override
>> @Override
>> return button;
>> @Override
>> setValue();
>> @Override
>> setValue();
>> markDirty();
>> } else {
>> @Override
>> @Override
>>>>> value.
>>>>> Text
>>>>> annoying
>>>>> continue
>>>> the model.
>>>> doesn't
>>>> get the update.
>>>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #333830 is a reply to message #333827] |
Wed, 07 January 2009 16:51   |
I'll try to put one together in the next few days.
>> Eric
>>> Eric
>>> labelProvider) {
>>> @Override
>>> @Override
>>> bubbled up to
>>> e.doit = false;
>>> return textField;
>>> @Override
>>> @Override
>>> @Override
>>> return button;
>>> @Override
>>> setValue();
>>> @Override
>>> setValue();
>>> markDirty();
>>> } else {
>>> @Override
>>> @Override
>>>>>> value.
>>>>>> Text
>>>>>> annoying
>>>>>> the
>>>>>> continue
>>>>> has
>>>>> into
>>>>> the model.
>>>>> doesn't
>>>>> get the update.
>>>>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #334143 is a reply to message #333827] |
Wed, 21 January 2009 22:33   |
Wouldn't you know it, I reduced it down to a snippet and now it seems to
be working correctly! Frustrating, but at least the community can
benefit from the work.
A question before I submit the snippet in bugzilla: I've got two
classes, the snippet and the cell editor class. If they are combined
into one (make the cell editor a nested class) I think the code is too
crowded and difficult to follow - that defeats the purpose of a snippet,
doesn't it? So can snippets consist of more than one top-level class?
Would I attach both .java files to the bug report?
Eric
>> Eric
>>> Eric
>>> labelProvider) {
>>> @Override
>>> @Override
>>> bubbled up to
>>> e.doit = false;
>>> return textField;
>>> @Override
>>> @Override
>>> @Override
>>> return button;
>>> @Override
>>> setValue();
>>> @Override
>>> setValue();
>>> markDirty();
>>> } else {
>>> @Override
>>> @Override
>>>>>> value.
>>>>>> Text
>>>>>> annoying
>>>>>> the
>>>>>> continue
>>>>> has
>>>>> into
>>>>> the model.
>>>>> doesn't
>>>>> get the update.
>>>>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #334150 is a reply to message #334143] |
Thu, 22 January 2009 02:43   |
Hi Eric,
Yes we have some snippets which consist of more than one class. Maybe
adding a comment in the class-javadoc to explain this could help.
Tom
> Eric
>>> Eric
>>>> Eric
>>>> labelProvider) {
>>>> @Override
>>>> @Override
>>>> bubbled up to
>>>> e.doit = false;
>>>> return textField;
>>>> @Override
>>>> @Override
>>>> @Override
>>>> return button;
>>>> @Override
>>>> setValue();
>>>> @Override
>>>> setValue();
>>>> markDirty();
>>>> } else {
>>>> @Override
>>>> @Override
>>>>>>> value.
>>>>>>> Text
>>>>>>> annoying
>>>>>>> the
>>>>>>> continue
>>>>>> has
>>>>>> needs
>>>>>> that
>>>>>> into
>>>>>> the model.
>>>>>> doesn't
>>>>>> get the update.
>>>>>> Eric
| Re: [JFace] Text and Dialog button CellEditor? [message #334156 is a reply to message #334150] |
Thu, 22 January 2009 09:50  |
Snippet submitted: https://bugs.eclipse.org/bugs/show_bug.cgi?id=262016
On 1/22/2009 2:43 AM, Tom Schindl wrote:
> Hi Eric,
> Tom
>> Eric
>>>> Eric
>>>>> Eric
>>>>> labelProvider) {
>>>>> @Override
>>>>> @Override
>>>>> bubbled up to
>>>>> e.doit = false;
>>>>> return textField;
>>>>> @Override
>>>>> @Override
>>>>> @Override
>>>>> return button;
>>>>> @Override
>>>>> setValue();
>>>>> @Override
>>>>> setValue();
>>>>> markDirty();
>>>>> } else {
>>>>> @Override
>>>>> if (textField != null&& labelProvider != null) {
>>>>> @Override
>>>>>>>> value.
>>>>>>>> Text
>>>>>>>> annoying
>>>>>>>> the
>>>>>>>> continue
>>>>>>> has
>>>>>>> needs
>>>>>>> that
>>>>>>> into
>>>>>>> the model.
>>>>>>> doesn't
>>>>>>> get the update.
>>>>>>> Eric
Current Time: Tue Nov 18 22:45:23 EST 2025
Powered by FUDForum. Page generated in 0.09293 seconds
