Home » Eclipse Projects » Eclipse Platform » Key bindings / Listen for changes
Key bindings / Listen for changes [message #332926] Fri, 14 November 2008 05:30
Originally posted by: mario.winterer.gmx.net
Hi!
In my UI there is a text control with a control decoration with a
description text that contains the key sequence of a certain command.
I've done this as follows:
IBindingService service = (IBindingService)
PlatformUI.getWorkbench().getService(IBindingService.class);
TriggerSequence triggerSequence =
service.getBestActiveBindingFor(COMMAND_ID);
(build decoration description using triggerSequence.format())
Now I want to listen for changes of key bindings to update the UI every
time, the binding of the given command changes. Unfortunately,
IBindingService does not offer any add/remove-listener methods.
What is the correct way to do that?
Mario
Previous Topic:question about resource traversal in eclipse
Next Topic:How to sort the preferences pages ?
Current Time: Wed Nov 19 00:38:33 EST 2025
Powered by FUDForum. Page generated in 0.03777 seconds
